- Một bạn gửi câu hỏi, mình xin post lên để các bạn cùng thảo luận và nhờ các mod giúp đỡ :wink:
*Bandwidth and delay have a range of values from 0 to 4,294,967,295 (in Kbps) and 0 to 4,294,967,295 (in 10-microsecond units), respectively. Reliability ranges from 0 to 255, with 255 being the most reliable. Load ranges from 0 to 255; however, a value of 255 means that the link is completely loaded. Finally, the value of MTU has the same range as the bandwidth variable: 0 to 4,294,967,295.
MTU =1500 chứ sao lại có range như bandwidth được?
* IGRP provides the ability of unequal-cost load balancing. The variance command is used to assign a weight to each feasible successor. A feasible successor is a predetermined route to use should the most optimal path be lost. The feasible successor can also be used as long as the secondary route conforms to the following three criteria, and an unequal-cost load balancing session may be established:
- A limit of four feasible successors may be used for load balancing. Four is the default; the maximum number of feasible successors is six
for IOS version 11.0 and later.
- The feasible successor’s metric must fall within the specified variance
of the local metric.
- The local metric must be greater than the metric for the next-hop
router.
mình ko hiểu tại sao phải vậy?Giải thích giùm mình?
*Cách mà IGRP hoạt động ở multiple sessions,và redistributed với những sessions khác nhau.
EIGRP chỉ báo cho những router nào cần biết về sự thay đổi, thế nó làm sao biết được trong all các neighbors của nó,cần báo cho ai và ko cần báo cho ai.
internal route processors là gì?
Vấn đề về route tag trong EIGRP:
Route tagging is used to distinguish routes learned by the different EIGRP
sessions. By defining a different AS number, EIGRP can run multiple sessions on a single router. Routers using the same ASN speak to each other and share routing information, which includes the routes learned and the advertisement of topology changes.
Route redistribution, which will be covered in its own section later in this
chapter, allows routes learned by one AS EIGRP session to be shared with
another session. When route distribution occurs, the routes are tagged as
being learned from an external EIGRP session. Each type of route is assigned its own administrative distance value.
*Mong mọi người giải thích giùm mình đoạn này.Đặc biệt chú ý đến việc EIGRP có thể chỉ dùng một AS number để nói chuyện với các sessions khác trong khi IGRP phải dùng các số AS khác nhau.
*24 nit format cho IGRP và 32 bit format cho EIGRP là gì ?
Route update và route caculation khác nhau ở chỗ:route update được gửi sau khi neighor đã được thiết lập,Router sẽ gửi toàn bộ routing table của nó cho neighbor,và từ đó chỉ có sự ảnh hưởng trực tiếp lên router từ một sự cố nào đó thì nó mới tính toán cho một đường mới,thông tin về một đường route mới được gửi đi gọi là routing calculation.Right?
Thân chào các bạn :wink:
router.
