QUESTION NO: 15
Which of the following statements is true about the BGP synchronization command?
(Select two)
A. Synchronization must be enabled when implementing a multi-homed BGP connection to
multiple ISPs.
B. If it is turned ON, a prefix learned from IBGP neighbor is valid only if a non-bgp (IGP)
route exists for that prefix.
C. Synchronization is necessary when peering with an EBGP neighbor.
D. Synchronization improves BGP routing convergence.
E. Synchronization can be turned off if all the transit routers in an Autonomous system
running full mesh IBGP.
