em còn chưa hiểu về bài tập IP. Mong thầy và các bạn cho em 1 số đề để em làm thêm và hiểu sâu về mảng IP
Cám ơn
Cám ơn
1. If mask 255.255.255.128 were used with a Class B network, how many subnets could
exist, with how many hosts per subnet, respectively?
a. 256 and 256
b. 254 and 254
c. 62 and 1022
d. 1022 and 62
e. 510 and 126
f. 126 and 510
2. If mask 255.255.255.240 were used with a Class C network, how many subnets could
a.16 and 16
b.14 and 14
c.12 and 12
d.8 and 32
e.32 and 8
f.6 and 30
g.30 and 6
3. Which of the following subnet masks lets a Class B network allow subnets to have up to
150 hosts and up to 164 subnets?
a.255.0.0.0
b.255.255.0.0
c.255.255.255.0
d.255.255.192.0
e.255.255.240.0
f.255.255.252.0
g.255.255.255.192
h.255.255.255.240
4. Which of the following subnet masks let a Class A network allow subnets to have up to
a.255.0.0.0
b.255.255.0.0
c.255.255.255.0
d.255.255.192.0
e.255.255.240.0
f.255.255.252.0
g.255.255.255.192
h.255.255.255.240
5. Which of the following are valid Class C IP addresses?
a. 1.1.1.1
b. 200.1.1.1
c. 128.128.128.128
d. 224.1.1.1
e. 223.223.223.255
6. What is the range for the values of the first octet for Class A IP networks?
a. 0 to 127
b. 0 to 126
c. 1 to 127
d. 1 to 126
e. 128 to 191
f. 128 to 192
7. How many valid host IP addresses does each Class C network contain?
a. 65,536
b. 65,534
c. 65,532
d. 32,768
e. 32,766
f. 256
g. 254
8. What valid host range is the IP address 172.16.10.22 255.255.255.240 a part of?
A. 172.16.10.20 through 172.16.10.22
B. 172.16.10.1 through 172.16.10.255
C. 172.16.10.16 through 172.16.10.23
D. 172.16.10.17 through 172.16.10.31
E. 172.16.10.17 through 172.16.10.30
9. What is the broadcast address of the subnet address 172.16.8.159 255.255.255.192?
A. 172.16.255.255
B. 172.16.8.127
C. 172.16.8.191
D. 172.16.8.255
10. What is the broadcast address of the subnet address 192.168.10.33 255.255.255.248?
A. 192.168.10.40
B. 192.168.10.255
C. 192.168.255.255
D. 192.168.10.39
11. If you wanted to have 12 subnets with a Class C network ID, which subnet mask would you use?
A. 255.255.255.252
B. 255.255.255.248
C. 255.255.255.240
D. 255.255.255.255
12. If you need to have a Class B network address subnetted into exactly 510 subnets, what subnet
mask would you assign?
A. 255.255.255.252
B. 255.255.255.128
C. 255.255.255.0
D. 255.255.255.192
13. If you are using a Class C network ID with two subnets and need 31 hosts per network, which
of the following masks should you use?
A. 255.255.255.0
B. 255.255.255.192
C. 255.255.255.224
D. 255.255.255.248
14. How many subnets and hosts can you get from the network 192.168.254.0/26?
A. 4 networks with 64 hosts
B. 2 networks with 62 hosts
C. 254 networks with 254 hosts
D. 1 network with 254 hosts
15. Write the subnet, broadcast address, and valid host range for each of the following:
a. 172.16.10.5 255.255.255.128
b. 172.16.10.33 255.255.255.224
c. 172.16.10.65 255.255.255.192
d. 172.16.10.17 255.255.255.252
e. 172.16.10.33 255.255.255.240
f. 192.168.100.25 255.255.255.252
g. 192.168.100.37 255.255.255.248
h. 192.168.100.66 255.255.255.224
i. 192.168.100.17 255.255.255.248
j. 10.10.10.5 255.255.255.252
Nếu cần thì google 1 phát là ra 1 khối bài tập để làm luôn đó bạn.
Nguyễn Thị Thanh Minh,
Support Teams
Email :thanhminh@vnpro.org
149/1D Ung Văn Khiêm P25 Q.Bình Thạnh TPHCM
Tel: (08) 35124257Fax: (08) 5124314Home Page : http://www.vnpro.vn
Support forum : http://vnpro.org
LiveChat : http://www.vnpro.vn/support
Wifi forum : http://wifipro.org
Blog : http://vnpro.org/blog
http://faculty.valleycollege.net/rpo...pt/subnet2.htm
Gởi bạn link làm bài tập và có lời giải.
Chúc bạn học tốt.
Email : gialiem@vnpro.org
Yahoo : gialiem_vnpro
Support Forum: http://www.vnpro.org- Chuyên đào tạo quản trị mạng và hạ tầng Internet
Bạn tham khảo tại đây:
http://www.mediafire.com/download.php?8a04hydgp18gryi
