CCIE Lab Technology Outline
- Bridging and Switching
- Frame-Relay
- HDLC/PPP
- Interior Gateway Routing
- Exterior Gateway Routing
- IP Multicast
- Quality of Service (QoS)
- IPv6
- Security
- System Management
- IP Services
- Miscellaneous
- Switchports
- Dynamic
- Access
- Trunk
- ISL
- 802.1q
- DTP
- Native VLAN
- Allowed List
- Tunnel
- 802.1q Tunnel
- L2TP
- Speed / Duplex
- VTP
- Domains
- Modes
- Authentication
- Pruning
- Prune Eligible List
- Extended VLANs
- Layer 3 Routing
- Router-on-a-Stick
- Native Routed Ports
- SVIs
- EtherChannel
- PAgP
- LACP
- Layer 3
- Load Balancing
- Spanning-Tree Protocol
- Root Election
- Path Selection
- Port Cost
- Port Priority
- Advanced Spanning-Tree Features
- Portfast
- Uplinkfast
- Backbonefast
- BPDU Guard
- BPDU Filter
- Loopguard
- Disabling STP
- Multiple Spanning-Tree Protocol
- Root Election
- Path Selection
- Advanced Catalyst Features
- Flex Links
- Private VLANs
- UDLD
- SPAN
- RSPAN
- Macros
- CAM Maintenance
- Static Entries
- Aging
- Logging
Frame-Relay
- NBMA Overview
- Interface Types
- Physical
- Multipoint Subinterface
- Point-to-Point Subinterface
- Address Resolution
- Static
- Self Mapping
- Dynamic
- Disabling Requests
- Disabling Per DLCI
- Broadcast Replication
- LMI
- Full Mesh
- Partial Mesh (Hub-and-Spoke)
- End-to-End Keepalives
HDLC/PPP
- Serial Clocking
- PPP Overview
- Authentication
- PAP
- CHAP
- CHAP Hostname
- CHAP Password
- Putting a "?" in Password
- Peer Neighbor Route
- IP Unnumbered
- Reliable Link
- Multilink
- PPP over Frame Relay (PPPoFR)
- Verification & Troubleshooting
- IP Routing
- Longest Match Routing
- Metric
- Distance
- Route Recursion
- Layer 2 Resolution
- Default Routing
- OSPF
- Network Statement
- Passive Interface
- Network Types
- Broadcast
- Non-Broadcast
- Point-to-Multipoint
- Point-to-Multipoint Non-Broadcast
- Point-to-Point
- Mismatch
- Virtual-Links
- Router-ID
- Stub Areas
- Stub
- Stub No-Summary
- NSSA No-Summary
- NSSA No-Redistribution
- NSSA No-Advertise
- GRE over Stub
- Filtering
- Distribute-List
- LSA 3 Filter
- Path Selection
- Auto-Cost
- Cost
- Bandwidth
- Neighbor Cost
- Convergence Timers
- Authentication
- Area
- Interface
- MD5
- Clear Text
- Null
- Virtual-Link
- Summarization
- Internal
- External
- Default Routing
- Always
- Conditional
- OSPF Demand Circuit
- EIGRP
- Network Statement
- Passive Interface
- Split-Horizon
- Metric Weights
- Authentication
- MD5
- Key Rotation
- Unicast Updates
- Summarization
- Auto-Summary
- Interface
- Default Routing
- Feasibility Condition
- Variance
- Metric Manipulation
- Stub Routing
- Bandwidth Percent
- RIP
- Network Statement
- Passive Interface
- Version
- Split-Horizon
- Summarization
- Auto Summary
- Interface Summary
- Filtering
- Distribute-List
- Offset List
- Distance
- Updates Types
- Broadcast
- Unicast
- Default Routing
- Authentication
- MD5
- Text
- RIP Triggered
- Redistribution
- Metric
- OSPF Metric Type
- Prefix Lists
- Route Filtering
- Poisoning Routes w/ Metric
- Miscellaneous
- On Demand Routing (ODR)
- Floating Static Routes
- Backup Interface
- Policy Routing
- GRE Tunneling
- Establishing Peerings
- TCP Transport
- Update Source
- Authentication
- EBGP
- iBGP
- Route Reflection
- Confederation
- Next-Hop Processing
- Next-Hop Self
- Route-Map
- iBGP Synchronization
- Redistribution into IGP
- BGP over GRE
- Bestpath Selection
- Weight
- Local Preference
- AS-Path Prepending
- MED
- Originating Prefixes
- Network Statement
- Redistribution
- Aggregation
- Summary-Only
- Suppress-Map
- Unsuppress-Map
- Filtering Specifics
- Filtering Aggregate
- Conditional Route Injection
- Default Originate
- Communities
- No-Export
- No-Advertise
- Local-AS
- Numbered
- New Format
- Local AS
- Conditional Advertisement
- Outbound Route Filtering
- Dampening
- Peer Groups
- Regular Expressions
- Remove Private AS
- Timers
- Fast External Fallover
- Max Prefix
IP Multicast
- IGMP
- Join
- Static
- Access- Group
- 3560 Profile
- Helper
- Timers
- Max Groups
- PIM
- Sparse
- Dense
- Sparse-Dense
- Reverse Path Forwarding
- Static Mroute
- RP Assignments
- Static
- Specific Groups
- Override
- Auto-RP
- Sparse-Dense
- Auto-RP Listener
- Default Static RP
- Specific Groups
- RP Announce Filter
- BSR
- Specific Groups
- Priority
- BSR Border
- NBMA Mode
- Stub Routing
- Shared/Source Trees
- IP PIM SPT-Threshold
- Multicast over GRE
- TTL Scoping
- Multicast Rate Limiting
- Legacy QoS
- MQC
- Classification
- Access-Lists
- IP Precedence
- DSCP
- NBAR
- Packet Length
- FR-DE
- Interface
- Not
- Congestion Management
- Custom Queue
- MQC Bandwidth
- Priority Queue
- MQC Priority
- Congestion Avoidance
- Legacy WRED
- MQC WRED
- IP Precedence
- DSCP
- Shaping
- Legacy GTS
- Legacy FRTS
- MQC Shape
- MQC FRTS
- Adaptive
- Policing
- Legacy CAR
- MQC Police
- Unconditional Packet Discard
- RSVP
- Nested MQC Policies
- 3560 QoS
- CoS
- Voice VLANs
- Priority Queue
- SRR
- Compression
- TCP Header
- Predictor
- Frame Relay RTP Header
IPv6
- Addressing
- Global Unicast
- Site Local
- Link Local
- EUI-64
- IPv6 over Ethernet
- ICMP ND
- Static to Next-Hop
- Static to Interface
- IPv6 over Frame Relay
- Layer 3 Resolution
- RIPng
- Enabling
- Default Routing
- Summarization
- Offset List
- Distribute-List
- OSPFv3
- Enabling
- Network Types
- OSPFv3 over NBMA
- Summarization
- Internal
- External
- Default Routing
- MBGP
- Address Families
- Network Statement
- Redistribution
- Aggregation
- Tunneling
- IPv6IP
- GRE
- Automatic 6to4
- Access-List Filtering
- Static IPv6 DNS Entries
Security
- Standard Access-Lists
- Extended Access-Lists
- Time Based Access-Lists
- Access-List Logging
- Reflexive Access-Lists
- Dynamic Access-Lists
- TCP Intercept
- Disabling Services
- Source Routing
- Proxy ARP
- IP Options
- CDP
- IP Unreachable
- Local Authentication
- Access-Class
- Local Authorization
- URPF
- 3560 Security
- 802.1x Authentication
- Storm Control
- VACLs
- Port Security
- Violation
- Protect
- Restrict
- Shutdown
- MAC Address
- Maximum
- Aging
- Time
- Type
- Errdisable Recovery
- Port Protection
- Switchport Block
System Management
- SNMP
- Polling
- Trapping
- Communities
- Controlling Access
- RMON
- Delta
- Absolute
- Logging
- Syslog
- 3560 Flash Logging
- Timestamps
- NTP
- Master
- Server
- Peer
- Authentication
- Timezones
- Banners
- Menus
- HTTP Server
- TFTP Server
- IOS Image Booting
- Aliases
- Autoinstall
- Refuse Message
- CDP
- Config Change Notification and Logging
- Crash Dump
IP Services
- NAT
- Inside Source
- TCP Load Balancing
- On a Stick
- Port Redirection
- DHCP
- Server
- Exclusions
- Domain
- Gateway
- Multiple Gateways
- Lease Time
- Client
- IPCP Client
- IP Helper
- DNS
- Static Entries
- Proxy
- IP Accounting
- Output Packets
- Access-List Violations
- Precedence
- Mobile IP
- First Hop Redundancy
- HSRP
- VRRP
- GLBP
- Tracking
- IP Alias
- Small Services
- Local Area Mobility
- Web Caching
- Inbound
- Outbound
- Exception
- IP SLA
- DRP Server
Miscellaneous
- Bridging
- Transparent
- CRB
- IRB
- Fallback Bridging
- Bridging over Frame Relay
