Results 1 to 2 of 2
Thread: Lab 15-3: Cấu hình Spase-mode tĩnh
  1. #1
    Default Lab 15-3: Cấu hình Spase-mode tĩnh
    Vẫn dùng sơ đồ trên, ta phải enable multicast trên toàn bộ router. Cấu hình địa chỉ RP tĩnh trên tất cả các router. Ở đây ta sẻ sử dụng R2 làm RP và sử dụng interface loopback 0 của R2 là địa chỉ của RP
    Lệnh router(config)# ip pim rp-address 192.168.4.1
    Cấu hình
    R1#
    hostname R1
    enable password cisco
    no ip domain lookup
    ip host Host_1 192.168.3.2
    ip host R3 192.168.1.18
    ip host R4 192.168.1.14
    ip host R5 192.168.1.6
    ip host r2 192.168.1.22
    interface Serial0/0
    ip address 192.168.1.1 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    clockrate 64000
    interface FastEthernet0/1
    ip pim sparse-mode
    no ip mroute-cache
    duplex auto
    speed auto
    interface Serial0/1
    ip address 192.168.1.21 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    clockrate 64000
    router ospf 1
    log-adjacency-changes
    network 0.0.0.0 255.255.255.255 area 0
    ip classless
    no ip http server
    End
    R2#
    hostname R2
    no ip domain lookup
    ip multicast-routing
    interface Loopback0
    ip address 192.168.4.1 255.255.255.255
    ip pim sparse-mode
    interface Serial0/0
    ip address 192.168.1.17 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    no fair-queue
    clockrate 64000
    interface Serial0/1
    ip address 192.168.1.22 255.255.255.252
    no ip mroute-cache
    ip pim sparse-mode
    router ospf 1
    ip classless
    ip http server
    End
    R3
    hostname R3
    no ip domain lookup
    interface Ethernet0/0
    ip pim sparse-mode
    no ip mroute-cache
    half-duplex
    interface Serial0/0
    ip address 192.168.1.13 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    no fair-queue
    interface Serial0/1
    ip address 192.168.1.18 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    router ospf 1
    ip http server
    ip classless
    End
    R4
    hostname R4
    ip address 192.168.1.5 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    half-duplex
    interface Serial0/0
    ip address 192.168.1.2 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    no fair-queue
    interface Serial0/1
    ip address 192.168.1.14 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    clockrate 64000
    router ospf 1
    ip classless
    ip http server
    End
    R5
    hostname R5
    ip subnet-zero
    no ip domain lookup
    interface FastEthernet0/0
    ip address 192.168.1.6 255.255.255.252
    ip pim sparse-mode
    no ip mroute-cache
    duplex auto
    speed auto
    ip pim sparse-mode
    no ip mroute-cache
    duplex auto
    speed auto
    router ospf 1
    ip classless
    ip http server
    End
    Show ip mroute
    R1#show ip mroute
    IP Multicast Routing Table
    Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
    L - Local, P - Pruned, R - RP-bit set, F - Register flag,
    T - SPT-bit set, J - Join SPT, M - MSDP created entry,
    X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
    U - URD, I - Received Source Specific Host Report, s - SSM
    Outgoing interface flags: H - Hardware switched
    Timers: Uptime/Expires
    Interface state: Interface, Next-Hop or VCD, State/Mode
    (*, 224.0.1.40), 00:54:11/00:00:00, RP 192.168.4.1, flags: SJCL
    Incoming interface: Serial0/1, RPF nbr 192.168.1.22
    Outgoing interface list:
    Serial0/0, Forward/Sparse, 00:53:52/00:00:00
    FastEthernet0/1, Forward/Dense, 00:54:11/00:00:00
    (*, 228.0.0.1), 00:53:48/00:02:59, RP 192.168.4.1, flags: SJCF
    FastEthernet0/1, Forward/Dense, 00:53:48/00:00:00
    Serial0/0, Forward/Sparse, 00:53:48/00:00:00
    (192.168.3.2, 228.0.0.1), 00:00:15/00:03:15, flags: CFT
    Incoming interface: FastEthernet0/1, RPF nbr 0.0.0.0
    Serial0/0, Forward/Sparse, 00:00:16/00:03:13
    R2#show ip mroute
    (*, 224.0.1.40), 00:54:22/00:00:00, RP 192.168.4.1, flags: SJCL
    Incoming interface: Null, RPF nbr 0.0.0.0
    Serial0/0, Forward/Sparse, 00:54:18/00:03:24
    Serial0/1, Forward/Sparse, 00:54:22/00:02:49
    (*, 228.0.0.1), 00:35:45/00:03:21, RP 192.168.4.1, flags: S
    Serial0/1, Forward/Sparse, 00:35:45/00:02:50
    Serial0/0, Forward/Sparse, 00:35:45/00:03:21
    (192.168.3.2, 228.0.0.1), 00:00:43/00:02:23, flags: PT
    Incoming interface: Serial0/1, RPF nbr 192.168.1.21
    Outgoing interface list: Null
    R3# show ip mroute
    U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
    Y - Joined MDT-data group, y - Sending to MDT-data group
    (*, 228.0.0.1), 00:53:39/stopped, RP 192.168.4.1, flags: SJC
    Incoming interface: Serial0/1, RPF nbr 192.168.1.17
    Ethernet0/0, Forward/Sparse, 00:53:39/00:02:34
    Serial0/0, Forward/Sparse, 00:53:39/00:00:00
    (192.168.3.2, 228.0.0.1), 00:00:57/00:02:48, flags: JT
    Incoming interface: Ethernet0/0, RPF nbr 192.168.2.2
    Serial0/0, Forward/Sparse, 00:00:57/00:02:02
    (*, 224.0.1.40), 00:54:33/00:02:24, RP 192.168.4.1, flags: SJCL
    Ethernet0/0, Forward/Sparse, 00:54:33/00:02:34
    Serial0/0, Forward/Sparse, 00:54:31/00:00:00
    R4#show ip mroute
    (*, 224.0.1.40), 00:54:57/00:00:00, RP 192.168.4.1, flags: SJCL
    Incoming interface: Ethernet0/0, RPF nbr 192.168.1.6
    Serial0/1, Forward/Sparse, 00:54:54/00:00:00
    Serial0/0, Forward/Sparse, 00:54:55/00:00:00
    (*, 228.0.0.1), 00:01:18/00:02:59, RP 192.168.4.1, flags: SP
    (192.168.3.2, 228.0.0.1), 00:01:18/00:02:51, flags: T
    Incoming interface: Serial0/0, RPF nbr 192.168.1.1
    Ethernet0/0, Forward/Sparse, 00:01:18/00:03:14
    R5#show ip mroute
    (*, 224.0.1.40), 00:55:53/00:00:00, RP 192.168.4.1, flags: SJCL
    Incoming interface: FastEthernet0/1, RPF nbr 192.168.2.1
    FastEthernet0/0, Forward/Sparse, 00:55:53/00:02:41
    (*, 228.0.0.1), 00:55:19/00:02:59, RP 192.168.4.1, flags: SJC
    FastEthernet0/0, Forward/Sparse, 00:55:15/00:00:00
    (192.168.3.2, 228.0.0.1), 00:01:37/00:01:22, flags: CT
    Incoming interface: FastEthernet0/0, RPF nbr 192.168.1.5
    FastEthernet0/1, Forward/Sparse, 00:01:37/00:03:26
    Kiểm tra
    Sử dụng lênh show ip pim rp
    R3#show ip pim rp
    Group: 228.0.0.1, RP: 192.168.4.1, uptime 00:13:50, expires never
    Group: 224.0.1.40, RP: 192.168.4.1, uptime 00:13:50, expires never
    Ở R5 tương tụ
    Sử dụng lênh Show ip pim rp map
    R5#show ip pim rp mapping
    PIM Group-to-RP Mappings
    Group(s) 224.0.1.39/32
    RP 192.168.4.1 (?), v1
    Info source: local, elected via Auto-RP
    Uptime: 00:11:28, expires: never
    Group(s) 224.0.1.40/32
    Group(s): 224.0.0.0/4, Static
    RP: 192.168.4.1 (?)
    Ở R3 tương tự
    Ta ping từ Host1 đến Host2:kiểm tra trên R3 và R5: debug ip mpacket
    R3#
    *Mar 1 00:39:48.723: IP(0): s=192.168.3.2 (Ethernet0/0) d=228.0.0.1 id=432, prot=1, len=114(100), not RPF interface
    *Mar 1 00:39:48.735: IP(0): s=192.168.3.2 (Serial0/1) d=228.0.0.1 (Ethernet0/0) id=432, prot=1, len=100(100),
    mforward
    *Mar 1 00:39:48.735: IP(0): s=192.168.3.2 (Serial0/1) d=228.0.0.1 (Serial0/0) id=432, prot=1, len=100(100), mforward
    *Mar 1 00:39:50.726: IP(0): s=192.168.3.2 (Ethernet0/0) d=228.0.0.1 id=433, prot=1, len=114(100), mroute olist null
    R5#
    *Mar 1 00:41:16.447: IP: s=192.168.3.2 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
    *Mar 1 00:41:18.451: IP: s=192.168.3.2 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
    *Mar 1 00:41:20.455: IP: s=192.168.3.2 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
    *Mar 1 00:41:22.459: IP: s=192.168.3.2 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
  2. #2
    Default
    sơ đồ bài lab ko có à đại ca. Nối linh tinh có được ko
Similar Threads
  1. CCNP Switching: Lab về dot1q Tunneling (rất dài)
    By dangquangminh in forum SWITCH / BCMSN
    Last Post: 21-06-2011, 05:25 AM
  2. 1 câu hỏi ngớ ngẩn về routing :P
    By Mr.Metal in forum Software
    Last Post: 07-06-2010, 04:12 PM
  3. Lab 1-1: Cấu hình switch cơ bản
    By admin in forum CCNP LabPro - CCNP Switching
    Last Post: 25-02-2009, 03:35 PM
  4. Help me! error Backup tren CNA
    By minhthu in forum SWITCH / BCMSN
    Last Post: 11-07-2008, 11:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
   TRUNG TÂM TIN HỌC VNPRO
Phone:(08) 35124257
Email: vnpro@vnpro.org
