Results 1 to 2 of 2
Thread: Một số nguyên nhân làm fail kỳ thi CCIE Lab
  1. #1
    Default Một số nguyên nhân làm fail kỳ thi CCIE Lab
    Bill Parkhust (Ph.D, CCIE) là thành viên chủ chốt của CCIE team của Cisco. Bill cũng là người ra các đề thi lab CCIE R&S. Bài viết dưới đây của Bill được trích trong Networker 2003, tuy nhiên nó vẫn giữ nguyên giá trị cho các bạn CCIE Candidate.
    Here is some great information found from a meeting with Bill Parkhurst and some Cisco SE's:
    The #1 reason for failure is lack of knowledge.
    * Study concepts. Do not try to memorize configurations or scenarios.
    For example, understand how an OSPF DR is chosen. The lab proctors
    generally power cycle all of the equipment BEFORE grading. This could
    change your OSPF DR if you didn't configure the router you want to always be the DR properly.
    * Practice each concept on its own. For example, practice OSPF
    WITHOUT also turning on BGP. This will ensure that any behaviours you see are attributed ONLY to OSPF and you don't confuse a behaviour that was caused by BGP to be an OSPF behaviour.
    * Practice Labs should be used for self evaluation. Time yourself when using a practice lab to simulate the CCIE Lab Exam experience. Only use the practice lab 1 time.
    The #2 reason for failure is anxiety.
    * To reduce anxiety, travel to your lab location early the day before. Visit the CCIE lab facilities the day before. Introduce yourself to the CCIE lab proctor the day before. Doing this will keep you from fretting over how to find the lab the day of your lab. Also, meeting your lab proctor is a big help.
    * Have confidence in your abilities. If you have been studying the technology and concepts, you are ready for ANY scenario. The primary R&S concepts include Layer 2 switching, VLANs, OSPF, FR, BGP, Multicast & ISDN. There is NO MPLS on the exam. IGRP and IPX have been removed from the exam.
    * Practice good test taking skills:
    * Skim the exam for the first 5 to 10 minutes once you get it.
    * Configure all L2 requirements FIRST.
    * Configure everything else in the exam that you know SECOND.
    * Use documentation or help commands to configure the remaining exam requirements that you are not familiar with LAST...remember this is a Pass or Fail exam. You only need 80 points. Not all 100 points.
    * If you believe you have a hardware problem, do NOT spend more than 10 minutes trying to fix the hardware. Ask the lab proctor to investigate the issue. The lab proctor will stop the clock and send you away while
    he/she checks the hardware. If it is a hardware problem, the proctor will
    resolve and restart your clock. If it is NOT a hardware problem, you will
    at least KNOW it is not a hardware problem. On the other hand, if you have a hardware problem that you spend 90 minutes trying to resolve, you will not regain this time after you and the proctor finally replace the hardware.
    * You are allowed to ask the proctor anything. But ask intelligent questions. For example, if you are unsure of what a question is asking, ask the proctor something like this:
    * If I interpret this question this way......then I plan to do X. But if I interpret this question this other way......then I plan to do Y. Which
    way should I interpret it?
    Miscellaneous:
    * Lab exams are usually about 17 pages long.
    * A new lab is written every month and an old lab is retired every month. There are more than 1 lab exams available to be given at any time. Each lab achieves roughly the same pass rate.
    * The average person that passes the CCIE exam takes 2.5 lab attempts.
    * There is often a 4- 6 month backlog to register for the exam.
    * CCIE candidates can cancel a lab exam up to 28 days before their
    exam date WITHOUT being charged. Therefore, if you are willing to take an exam in 4 weeks, you can usually schedule it in 4 weeks. Otherwise, your lab exam will probably be 4-6 months out.
    * Grading is done with an automated script. The script gives full
    credit for any question that works properly. If a particular question does
    not work properly, the lab proctor manually checks to validate whether or
    not the question was answered properly. Partial credit is not given. 5
    point questions are rare. When they do occur, there is usually a modular
    piece to it so that 2 or 3 points can be earned without getting all 5
    points.
    * The RTP lab uses SecureCRT as the terminal emulator. This seems to
    be preferred. The San Jose lab uses Windows.
    Hope you found this useful.
  2. #2
    Default Re: Một số nguyên nhân làm fail kỳ thi CCIE Lab
    Quote Originally Posted by Admin
    Miscellaneous:
    points.
    Nguyên nhân lớn nhất là do không đủ kiến thức:
    * Hãy học các khái niệm. Đừng học các cấu hình hay các tình huống. Ví dụ, hãy học và hiểu OSPF DR được bầu chọn như thế nào. Khi các thầy chấm bài, họ thường tắt các router đi rồi bật lại. Do đó OSPF DR của bạn có thể bị thay đổi.
    * Thực tập các công nghệ riêng lẽ trước. Ví dụ thực tập các bài thực hành của riêng OSPF mà không có BGP. Điều này đảm bảo rằng một trạng thái kỳ lạ nào đó mà bạn thấy là của OSPF chứ không phải của BGP hay một giao thức khác.
    * Các bài thực tập lab chỉ được dùng để tự đánh giá. Khi làm các bài lab này, nên chú ý đến thời gian. Mỗi quyển lab chỉ nên làm một lần.
    Nguyên nhân thứ hai là do lo lắng
    * Để giảm bớt lo lắng, hãy đi đến nơi thi sớm. Trước khi thi một ngày cũng nên ghé phòng lab và chào ông thầy proctor.
    * Tự tin vào khả năng của bạn. Nếu bạn đã học mọi khái niệm và đã thực tập đầy đủ, bạn sẽ có khả năng đối đầu với mọi tình huống. Trong bài thi R&S không có MPLS.
    Các kỹ năng quan trọng trong khi thi
    * Dành ra 5 hoặc 10 phút để đọc đề thi.
    * Cấu hình L2 trước.
    * Cấu hình mọi thứ trong đề thi mà bạn biết ở bước kế tiếp.
    * Dùng các lệnh help hay các document để cấu hình những thứ còn lại. Hãy nhớ rằng đây là một kỳ thi Đậu hoặc Rớt, bạn không cần 100 điểm để pass, bạn chỉ cần 80 điểm.
    * Nếu bạn gặp một vấn đề mà bạn nghĩ là do phần cứng, đừng tốn nhiều hơn 10' để khắc phục. Hãy yêu cầu proctor kiểm tra hardware giúp bạn.
    * Bạn được quyền hỏi proctor mọi thứ, nhưng hãy hỏi một cách thông minh. Ví dụ, bạn có thể hỏi" Trong câu hỏi này, nếu tôi hiểu như vậy thì giải pháp là A, nếu tôi hiểu là B thì giải pháp cho vấn đề là C". Tôi phải nên hiểu cách nào?
    * Đề thi lab dài 17 trang giấy A4, làm trong 8 giờ. Địa chỉ IP đã được cấu hình sẵn cho bạn.
    * Mỗi tháng có một đề thi lab mới được viết. Mỗi đề thi lab đều có tỉ lệ đậu / rớt giống nhau.
    * Bình quân mỗi thí sinh phải mất 2.5 lần thi.
    * Việc chấm thi được thực hiện bằng một script tự động. Nếu một phần nào đó hoạt động đúng, điểm của nguyên phần đó sẽ đựoc cho. Nếu bạn không làm đúng cho phần đó, người gác thi sẽ xem qua cấu hình của bạn. Các yêu cầu ở mức 5 điểm rất hiếm. Thông thường sẽ được chia ra thành các yêu cầu 2 điểm hoặc 3 điểm.
    * Chương trình hyperterminal được dùng là SecureCRT.
Similar Threads
  1. Những thành viên xuất sắc của VnPro (updated ngày 1/12/2008)
    By admin in forum Tôi đã thi đậu chứng chỉ quốc tế
    Last Post: 18-08-2009, 04:42 PM
  2. Tips for CCIE Candidate
    By binhhd in forum CCIE Routing & Switching
    Last Post: 22-04-2009, 02:01 PM
  3. Vì sao tôi Fail CCIE lần thứ ba !
    By PhungHai in forum Góc Thư Giãn
    Last Post: 22-10-2008, 11:12 AM
  4. Lời khuyên của một CCIE kinh nghiệm cho những người newbie
    By sinhvienngheo in forum Dành cho người mới đến
    Last Post: 20-11-2003, 01:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
   TRUNG TÂM TIN HỌC VNPRO
Phone:(08) 35124257
Email: vnpro@vnpro.org
