Sự cố leasedline rất cần được giúp đỡ help !!!!
  • Sự cố leasedline rất cần được giúp đỡ help !!!!
    Em đang thực tập quản trị mạng cho 1 công ty .Công ty có 1 đường leasedline giga0/1.7 nối thẳng đến chi nhánh .Từ đầu công ty ping được địa chỉ IP chi nhánh ,nhưng khi quảng bá ospf không nhận được neighbor ?? .Đây là bảng show run và show int ,mong các cao thủ giúp đỡ
    +SHOW IP INT BRI :
    ctnbi_rt01#show ip int brief
    GigabitEthernet0/0 10.27.65.241 YES NVRAM up up
    GigabitEthernet0/1 unassigned YES NVRAM up up
    GigabitEthernet0/1.4 172.19.48.74 YES NVRAM up up
    GigabitEthernet0/1.5 172.19.48.66 YES NVRAM up up
    GigabitEthernet0/1.7 172.16.24.18 YES NVRAM up up
    Loopback0 172.16.25.247 YES NVRAM up up
    Tunnel0 172.16.24.161 YES NVRAM up up
    Tunnel1 172.16.24.165 YES NVRAM up down
    Tunnel2 172.16.24.169 YES NVRAM up up
    Tunnel3 172.16.24.173 YES NVRAM up up
    Tunnel4 172.16.24.177 YES NVRAM up up
    Tunnel5 172.16.24.189 YES NVRAM up up
    Tunnel6 172.16.24.181 YES NVRAM up up
    Tunnel7 172.16.24.185 YES NVRAM up up
    Tunnel8 172.16.24.14 YES NVRAM up up
    +SHOW INT GIGA0/1.7 :
    ctnbi_rt01#show int gigabitEthernet 0/1.7
    GigabitEthernet0/1.7 is up, line protocol is up
    Hardware is CN Gigabit Ethernet, address is f866.f24c.e1d1 (bia f866.f24c.e1d1)
    Description: EVN_LEASED_LINE
    Internet address is 172.16.24.18/29
    MTU 1500 bytes, BW 2048 Kbit/sec, DLY 100 usec,
    reliability 255/255, txload 3/255, rxload 1/255
    Encapsulation 802.1Q Virtual LAN, Vlan ID 7.
    Keepalive not set
    ARP type: ARPA, ARP Timeout 04:00:00
    +SHOW IP OS NEI :
    ctnbi_rt01#show ip os neighbor
    Neighbor ID Pri State Dead Time Address Interface
    172.16.25.239 0 FULL/ - 00:00:35 172.16.24.190 Tunnel5
    172.16.25.240 0 FULL/ - 00:00:35 172.16.24.186 Tunnel7
    172.16.25.241 0 FULL/ - 00:00:37 172.16.24.182 Tunnel6
    172.16.25.242 0 FULL/ - 00:00:35 172.16.24.178 Tunnel4
    172.16.25.243 0 FULL/ - 00:00:37 172.16.24.174 Tunnel3
    172.16.25.244 0 FULL/ - 00:00:37 172.16.24.170 Tunnel2
    172.16.25.246 0 FULL/ - 00:00:35 172.16.24.162 Tunnel0
    172.16.25.253 0 FULL/ - 00:00:38 172.16.24.13 Tunnel8
    +SHOW RUN :
    ctnbi_rt01#show run
    interface GigabitEthernet0/1
    duplex auto
    speed auto
    interface GigabitEthernet0/1.4
    description Ket noi modem CT - CCT
    encapsulation dot1Q 4
    ip address 172.19.48.74 255.255.255.248
    interface GigabitEthernet0/1.5
    description Ket noi modem CT - KBNN
    encapsulation dot1Q 5
    ip address 172.19.48.66 255.255.255.248
    interface GigabitEthernet0/1.7
    description EVN_LEASED_LINE
    bandwidth 2048
    encapsulation dot1Q 7
    ip address 172.16.24.18 255.255.255.248
    ip mtu 1464
    ip ospf authentication message-digest
    ip ospf message-digest-key 1 md5 7 1501040203222A2A
    ip ospf hello-interval 5
    ip ospf dead-interval 40
    no keepalive
    no cdp enable
    router ospf 1
    log-adjacency-changes
    auto-cost reference-bandwidth 1000
    redistribute static subnets route-map LanCT
    passive-interface GigabitEthernet0/0
    network 10.27.65.0 0.0.0.255 area 0
    network 172.16.24.12 0.0.0.3 area 0
    network 172.16.24.16 0.0.0.7 area 0
    network 172.16.24.160 0.0.0.3 area 0
    network 172.16.24.164 0.0.0.3 area 0
    network 172.16.24.168 0.0.0.3 area 0
    network 172.16.24.172 0.0.0.3 area 0
    network 172.16.24.176 0.0.0.3 area 0
    network 172.16.24.180 0.0.0.3 area 0
    network 172.16.24.184 0.0.0.3 area 0
    network 172.16.24.188 0.0.0.3 area 0
    network 172.16.25.247 0.0.0.0 area 0
    ip forward-protocol nd
    ip http server
    no ip http secure-server
    ip route 10.27.64.0 255.255.255.0 10.27.65.1
    ip route 172.19.48.8 255.255.255.248 172.19.48.65
    ip route 172.19.48.128 255.255.255.248 172.19.48.73
    ip route 172.19.48.144 255.255.255.248 172.19.48.73
    ip route 172.19.48.160 255.255.255.248 172.19.48.73
    ip route 172.19.48.176 255.255.255.248 172.19.48.73
    ip route 172.19.48.192 255.255.255.248 172.19.48.73
    ip route 172.19.48.208 255.255.255.248 172.19.48.73
    ip route 172.19.48.224 255.255.255.248 172.19.48.73
    ip route 172.19.48.240 255.255.255.248 172.19.48.73
    access-list 1 permit 10.27.64.0 0.0.0.255
    access-list 100 permit ip any any
    access-list 102 permit ip 10.27.0.0 0.0.255.255 10.27.64.0 0.0.1.255
    access-list 102 permit ip 10.64.0.0 0.1.255.255 10.27.64.0 0.0.1.255
    access-list 102 permit ip 10.192.254.0 0.1.0.255 10.27.64.0 0.0.1.255
    access-list 102 permit ip host 10.27.65.241 10.27.64.0 0.0.1.255
    access-list 102 permit ip any host 10.27.65.10
    access-list 102 permit ip any host 10.27.65.11
    access-list 102 permit ip any host 10.27.64.51
    access-list 102 permit ip any host 10.27.64.61
    MONG CÁC CAO THỦ GIÚP ĐỠ
    Nguyên nhân ko thiết lập được Neighbor có thể là do time Hello-Interval và Deal-Interval Mismatch giữa hai đầu Công ty và chi nhánh. bạn có thể tetnet vào Con Chinh nhánh Show lên mình nghĩ dễ có thêm thông tin dễ troubleshoot hơn.
      Lót dép ngồi hóng
        Mình chỉ quản lý trên con router của công ty mình thôi ,phía kia mình không có quyền telnet .Vấn đề này mình đã xác định được sự cố rồi ,khi mình traceroute đến IP đầu leasedline của chi nhánh ,thì thấy gói tin phải đi đường vòng .Mình telnet vào con modem trên đường leasedline kiểm tra thì thấy cổng adsl/1 bị down ,do EVN lỗi đường truyền .Cám ơn ý kiến của bạn .
          Show ip ospf neighbor đã xuất hiện trạng thái FULL có nghĩa bảng neighbor đã đc tạo !!!
          Vấn đề còn lại là do bạn quảng bá như thế nào, do cấu hình bạn đưa quá ít ko thể kiểm tra đc!
          Thân!!!
            Originally posted by hoccisco View Post
            Show ip ospf neighbor đã xuất hiện trạng thái FULL có nghĩa bảng neighbor đã đc tạo ra không liên quan gì đến mismatch các timer cả!
            Bạn ơi ,đây là show ip ospf nei của tất cả các đường mà ,1 đường mismatch thì sẽ không hiện trong bảng neighbor .Thân
              Oh, sorry mình đọc ko lỹ cứ tưởng tunnel 7 map đến giga0/1.7
              Vấn đề này cho mình hỏi cổng này có thực sự là leasedline?
              Có vẻ như đây là cấu hình Metronet với việc sử dụng subinterface để add các VLAN, nếu như cổng up và như bạn nói ping tới đc đầu kia tức ip thuộc đường mạng 172.16.24.16/29 thì bạn kiểm tra lại xem thử xem môi trường bạn chạy qua có hỗ trợ Broadcast hay ko? Nếu không thì phải cấu hình bằng tay câu lệnh neighbor trên thiết bị để đảm bảo IP Dest trong gói tin hello thay thế cho địa chỉ multicast.
              Thân!!!
                Oh, sorry mình đọc ko kỹ cứ tưởng tunnel 7 map đến giga0/1.7
                Có vẻ như đây là cấu hình Metronet với việc sử dụng subinterface để add các VLAN, nếu như cổng up và như bạn nói ping tới đc đầu kia tức ip thuộc đường mạng 172.16.24.16/29 thì bạn kiểm tra lại xem thử xem môi trường bạn chạy qua có hỗ trợ Broadcast hay ko? Nếu không thì phải cấu hình bằng tay câu lệnh neighbor trên thiết bị để đảm bảo IP-Dest là IP của router đầu xa trong gói tin hello thay thế cho địa chỉ multicast.
                Thân!!!
                  Đúng là bạn chỉ đc đứng trên local router mà show thôi, ping thì ping đc nghĩa là L2 và L3 xong rồi. Còn việc tạo OSPF neighbor thì nó phải match nhiều yếu tố trong Hello, bạn show nhưng show 1 phía thì ko ai giúp gì bạn cả vì sao biết bên kia thế nào. Cái bạn cần làm giờ là #show ip osppf inter G0/1.7 và #debug rồi xem lỗi ở đâu, lúc đó mới có giải pháp cho bạn đc
