Results 1 to 6 of 6
Thread: Mot Vai Cau Hoi Moi Trong CCNA -Xin giup do
  1. #1
    Default Mot Vai Cau Hoi Moi Trong CCNA -Xin giup do
    Sau day la mot vai cua hoi moi minh moi update, nhung dang vuong mac bio mot so dap an .Xin cac thay va cac ban nao de test cho minh dap an chinh xac
    408.
    Which three statements accurately describe layer 2 Ethernet switches?(choose three)
    A. Microsegmentation decreases the number of collisions on the network.
    B. if a switch receives a frame for an unkown destination,it uses ARP to resolve the address.
    C. Spanning Tree Protocol allows switches to automatically share vlan information.
    D. In a properly functioning network with redundant switched paths,each swiched aegment will contain one
    root bridge with all its ports in the forwarding state.All other switches in that broadcast domain will have
    only one root port.
    E. Establishing vlans increases the number of broadcast domains.
    F. Switches that are configured with vlans make forwarding decisions based on both layer 2 and layer 3
    address information.
    Answer: ADF -----Dap an F dung hay E dung nhat?
    417.
    Which two statements apply to dynamic access lists?(choose two)
    A. they offer simpler management in large internetworks.
    B. you can control logging messages.
    C. they allow packets to be filtered based on upper-layer session information.
    D. you can set a time-based security policy.
    E. they provide a level of security against spoofing.
    F. they are used to authenticate individual users.
    Answer: CD --dap an khac AF? Dap an nao dung nhat?
    432.
    Refer to the graphic(router------SwitchB------SwitchA-----PC-A).Switch A connect to Switch B by trunk F0/1. Out put of Switch A show vlan1 (no ip is assigned), no ip gateway.
    Computer 1 is consoles into switch A.Telnet connections and pings run from the
    command prompt on switch A fail.Which of the following could cause this problem?
    A. switch A dose not have a cdp entry for switch B or router JAX
    B. switch A dose not have an IP address
    C. port 1 on switch A should be an access port rather than a trunk port
    D. switch A is not directly connected to router JAX
    E. switch A does not have a default gateway assigned
    Answer: E ---co dap an khac la B ? Dap an nao dung .
    451.
    Which three approaches can be used while migrating from an IPV4 addressing scheme to an IPV6
    scheme.(choose three)
    A. statically map IPV4 address to IPV6 addresses
    B. configuration IPv4 tunnels between IPV6 islands
    C. use DHCPv6 to map IPV4 addresses to IPV6 addresses
    D. use proxying and translation to translate IPV6 packets into IPV4 packets
    E. configure IPV6 directly
    F. enable dual-stack routing
    Answer: ABF ---dap an khac la BDF? Dap an nao dung vay?
    457.
    Which IPV6 routing protocol uses multicast group FFO2::8 to send updates?
    A. RIPng
    B. OSPFv3
    C. IS-IS for IPv6
    D. static
    Answer: C ---Dap an khac la D (theo chuan RFC nao do minh doc la ST)? Dap an nao dung?
    484.
    What are two benefits of using NAT?(choose two)
    A. NAT protects network security because private networks are not advertised.
    B. NAT accelerates the routing process because no modifications are made on the packets.
    C. Dynamic NAT facilitates connections from the outside of the network.
    D. NAT facilitates end-to-end communication when IPsec is enable.
    E. NAT eliminates the need to re-address all host that require extemal access.
    F. NAT conserves addresses through host MAC-level multiplexing.
    Answer: AE ---dap an khac la AC ? cai nao dung day?
    xin quy thay giup em nhung dap an nay. Tai nhung dap an nay tren mang 9tut co nhieu y kien y co qua, ko biet chinh xac, ma minh cung chua test duoc. Tien day dao nay thay tren 9tut co nhieu nguoi dau voi hon 900/1000 voi bo de update nay
    http://www.4shared.com/document/new5...uestion_a.html
    chi can on ACME voi nhung cau hoi update trong day, neu can them Ti v21.8 hay pass 4sure 533 cau la Ok. Lab van nhu cu EIGRP, VTP, ACL2.
    Nhung cau hoi minh hoi no nam trong bo update moi nay, moi nguoi xem can can nhac.
  2. #2
    Join Date
    Aug 2010
    Location
    BinhThanh - HCMC
    Posts
    456
    Default
    trong thời gian đợi mấy thầy trả lời, mình chọn giúp bạn vài câu trước.
    đối với câu 408
    Đáp án F sai, SW layer2 vẫn tồn tại nhiều vlan, nhưng nó forward based on layer 2 thôi. Còn câu E thì quá chính xác -> chọn E
    câu 417
    Câu 432: Đáp án B đúng, để telnet thì cần phải có IP, còn Defaut gateway có hay không, trong trường hợp này không quan trọng.
    Câu 451: Mình chọn ABF. Đối với câu A, có lẽ người hỏi muốn ám chỉ kỹ thuật Static NAT-PT. Cái này mình biết. Còn câu D: Proxy để translate IPV6 thành IPV4, chưa bao giờ gặp. Nhiều khả năng nó viết đại ra -> D sai.
    câu 457: đáp án là D. Bạn có thể tham khảo tại đây http://www.iana.org/assignments/ipv6...-addresses.xml. Nó là static host Multicast. Đối với Is-is là Open System Interconnection (OSI) dynamic routing protocol. Sử dụng OSI Connectionless Network Service (CLNS) chư không phải xài IP. ISIS chỉ có multicast layer 2. Do đó câu C sai.
    Câu 484: Câu này có vẻ mơ hồ, không dám chắc. Mình chọn AE. Đối với câu C, theo mình thì Dynamic NAT chỉ giúp tạo điều kiện từ inside đi ra ngoài, chứ không phải outside đi vô trong -> Đáp án C sai.
  3. #3
    Join Date
    Aug 2010
    Location
    BinhThanh - HCMC
    Posts
    456
    Default
    Câu 417: Sau khi tìm hiểu, mình chọn câu CD.
    Sau đây là trích 1 số cái mình đọc được:
    Lock and key, also known as dynamic ACLs, was introduced in Cisco IOS Software Release 11.1. This feature is dependent on Telnet, authentication (local or remote), and extended ACLs.
    Lock and key configuration starts with the application of an extended ACL to block traffic through the router. Users that want to traverse the router are blocked by the extended ACL until they Telnet to the router and are authenticated. The Telnet connection then drops and a single-entry dynamic ACL is added to the extended ACL that exists. This permits traffic for a particular time period; idle and absolute timeouts are possible.
    Lock-and-key access allows you to set up dynamic access lists that grant access per user to a specific source/destination host through a user authentication process. User access is allowed through a Cisco IOS® Firewall dynamically, without any compromise in the security restrictions.
    Spoofing is a problem with all existing access lists. Lock-and-key access does not address this problem.
    Spoofing la 1 diem yeu cua Dynamic access list nên câu E chắc chắn sai.
    Đối với câu A, cái này cũng không liên quan gì.
    Tính năng này dựa trên telnet (layer 4) -> Đáp án C đúng
    Ngoài ra khi 1 dòng access-list được tạo ra động, sau 1 khoảng thời gian nó sẽ tự xóa đi -> đáp án D đúng.
  4. #4
    Default
    Cam on ban da giup do minh giai dap nhung cau hoi nay nhung minh van con mot so ngo vuc, khi ban dap an mot so cauhoi. Vi hom bua mang len hoi thay Duy Huy voi mot so cau hoi sau:
    408. Dap an e la dung nhung co phu hop voi cau hoi khong. Ho noi ve switch chu hoi ve Vlan dau (so lac huong, ko dung y cau hoi). Thu hai, khong phai hoan toan cau F la sai vi mot phan no de cap den hoat dong cua switch , mot phan khong hoan toan switch forward goi tin tren layer 2 het. Ban co the lay nguon tin nao de comfirm lai chuyen nay khong.
    457. Day la giao thuc dinh tuyen con static conn lien quan gi den giao thuc dinh tuyen khong ban. Do vay minh moi thac mac, con link ban dua minh da biet chuyen nay roi. Chinh vithe minh moi phan van. Ban confirm lai di.
    Dieu cuoi cung la sao minh thay nhieu ban pass voi bo de nay v.218 ma khong co van de gi voi nhung dap an , sao tren 9tut nhieu nguoi dua dap an tum lum ma hau het la nguoi chua thi . Mot dieu kho hieu.
  5. #5
    Join Date
    Aug 2010
    Location
    BinhThanh - HCMC
    Posts
    456
    Default
    sorry bạn, câu 457 đáp án của mình sai, tìm hiểu chưa kỹ, ST ở đây không phải là Static. Hic. Nó là Internet Stream Protocol. Để tìm hiểu cái RFC 1190 thêm. Có thể sẽ trả lời được.
    CÒn 408, chắn chắn câu F sai rồi bạn, Câu hỏi người ta đề cập layer 2 SW, thì làm sao forward based layer 3 được. Trong khi vlan là khái niệm layer 2. Còn gì đâu mà ngờ vực.
    Tiếp: sau khi tìm hiểu khái quát, mình thấy OSPFv3, RIPng, ISIS đều không liên quan tới ST.
    Đối với câu D: Static. Có thể người soạn đề cũng lầm tưởng như mình lúc đầu, thấy chứ ST, lại nghĩ static nên soạn đề ghi static, Chứ cái nguyên gốc ban đầu của CISCO là chữ ST -> Chọn đáp án D.
  6. #6
    sunny_ntc Guest
    Default
    394.
    You are working in a data center environment and are assigned the address range 10.188.31.0/23.You are
    asked to develop an IP addressing plan to allow the maximum number of subnets with as many as 30
    hosts each
    .Which IP address range meets these requirements?
    A. 10.188.31.0/27
    B. 10.188.31.0/26
    C. 10.188.31.0/29
    D. 10.188.31.0/28
    E. 10.188.31.0/25
    Answer: B --> /26 có 2^3 và 62host/subnet
    Mình nghĩ câu này A mới đúng chứ ! /27 thì sẽ có 2^4 subnet và 30host/Subnet ! Ai cho ý kiến với
Posting Permissions
  • You may not post replies
  • You may not edit your posts
