Frame Relay Full Mesh
  • Frame Relay Full Mesh
    Cấu hình Frame Relay Point to point, dạng full-mesh. R2 và R3 có kết nối trực tiếp, chứ không thông qua R1 như mô hình dạng Hub&Spoke .
    Chạy định tuyến RIP để quảng bá mạng cho nhau và mạng hội tụ, tất cả IP ping thấy nhau .
    FRSW:
    sh run
    hostname FRSW
    no aaa new-model
    ip subnet-zero
    frame-relay switching
    ip cef
    interface Serial1/1
    encapsulation frame-relay
    serial restart-delay 0
    frame-relay intf-type dce
    frame-relay route 102 interface Serial1/2 201
    frame-relay route 103 interface Serial1/3 301
    interface Serial1/2
    frame-relay route 201 interface Serial1/1 102
    frame-relay route 203 interface Serial1/3 302
    interface Serial1/3
    frame-relay route 301 interface Serial1/1 103
    frame-relay route 302 interface Serial1/2 203
    ip classless
    FRSW#
    R1:
    sh run
    hostname R1
    ip subnet-zero
    ip cef
    interface Loopback1
    ip address 1.1.1.1 255.255.255.0
    interface Serial1/1
    interface Serial1/1.12 point-to-point
    ip address 192.168.12.1 255.255.255.0
    frame-relay interface-dlci 102
    interface Serial1/1.13 point-to-point
    ip address 192.168.13.1 255.255.255.0
    frame-relay interface-dlci 103
    router rip
    network 1.0.0.0
    network 192.168.12.0
    network 192.168.13.0
    ip classless
    no ip http server
    no ip http secure-server
    R1#
    R2:
    sh run
    hostname R2
    ip subnet-zero
    ip cef
    interface Loopback1
    ip address 2.2.2.2 255.255.255.0
    interface Serial1/2
    interface Serial1/2.21 point-to-point
    ip address 192.168.12.2 255.255.255.0
    frame-relay interface-dlci 201
    interface Serial1/2.23 point-to-point
    ip address 192.168.23.2 255.255.255.0
    frame-relay interface-dlci 203
    router rip
    network 2.0.0.0
    network 192.168.23.0
    ip classless
    R2#
    R3:
    sh run
    hostname R3
    ip subnet-zero
    no ip cef
    interface Loopback12
    ip address 3.3.3.32 255.255.255.0
    interface Serial1/3
    interface Serial1/3.31 point-to-point
    ip address 192.168.13.3 255.255.255.0
    frame-relay interface-dlci 301
    interface Serial1/3.32 point-to-point
    ip address 192.168.23.3 255.255.255.0
    frame-relay interface-dlci 302
    router rip
    network 3.0.0.0
    ip classless
    R3#
    Trịnh Anh Luân
    - Search my site
    - Search VNPRO.ORG
  • Phát hành sách chuyên môn
    Mình cũng cấu hình y như bài của bạn nhưng không biết tại sao lại không chạy? Mình làm trên GNS3 với con c7200 và dùng ISO c7200-jk9o3s-mz.124-12.bin. Có khi nào là do GNS3 hay do cái ISO không bạn?
      Bạn show run các router lên để xem thử, chắc có vấn đề gì đó, mà bạn chưa tìm ra.
      Trịnh Anh Luân
      - Search my site
      - Search VNPRO.ORG
        cảm ơn bạn nhiều. Mình đã làm được rồi. Cũng không biết là sai ở đâu (hay do cái ISO):106:, sửa hoài mệt quá@-) nên mình quyết định làm lại từ đầu với 1 ISO khác[-o< và cuối cùng là thành công=D>. Cảm ơn bài viết của bạn :113:
          Nhiều khi do cấu hình, cũng hơi phức tạp, có thể gõ sai gì đó mà nhìn hoài ko ra. nên... ^_^.
          Trịnh Anh Luân
          - Search my site
          - Search VNPRO.ORG
            tương tự vậy
            sau vài giây thì delete ko hiue63 vì sao?
              Bạn show run lên thử xem ?!
              Trịnh Anh Luân
              - Search my site
              - Search VNPRO.ORG
                Chào bác luancb !
                bác cho e hỏi nếu 3 mạng loopblack e dùng 3 định tuyến khác nhau thì sao nhỉ?
                làm sao để chúng thấy nhau!
                Hình như theo lý thuyết thì qua frame-relay là ko được hả bác?
                mạng 1.1.1.0/24 dùng rip
                mạng 2.2.2.0/24 dùng eigrp 100
                mạng 3.3.3.0/24 dùng ospf 200
                thì sao bác nhỉ?
                  Chạy định tuyến khác nhau, bạn phải sử dụng công cụ Redistribute để cho các mạng thấy nhau.
                  Trịnh Anh Luân
                  - Search my site
                  - Search VNPRO.ORG
                    cụ thể là e làm cái bài này
                    HP
                     Router#sho run
                    Current configuration : 2333 bytes
                    version 12.4
                    hostname Router
                    boot-start-marker
                    boot-end-marker
                    no aaa new-model
                    resource policy
                    memory-size iomem 5
                    ip flow-cache timeout active 5
                    ip cef
                    no ip domain lookup
                    interface Loopback0
                     ip address 20.0.1.1 255.255.255.0
                    interface Loopback1
                     ip address 20.0.3.1 255.255.255.0
                    interface Loopback2
                    interface Loopback3
                     ip address 20.0.4.1 255.255.255.0
                    interface Loopback4
                     ip address 20.0.5.1 255.255.255.0
                    interface Serial0/0
                     ip address 20.0.0.1 255.255.255.0
                     ip route-cache flow
                     no dce-terminal-timing-enable
                    interface Serial0/1
                     frame-relay lmi-type ansi
                    interface Serial0/1.1 point-to-point
                    interface Serial0/1.2 point-to-point
                     frame-relay interface-dlci 202
                    interface Serial0/2
                     shutdown
                    interface Serial0/3
                     shutdown
                    interface FastEthernet1/0
                     ip address 22.0.0.1 255.255.255.0
                     duplex auto
                     speed auto
                    router ospf 100
                     log-adjacency-changes
                     redistribute connected subnets
                     redistribute rip subnets
                     network 20.0.1.0 0.0.0.255 area 100
                     network 20.0.2.0 0.0.0.255 area 100
                     network 20.0.3.0 0.0.0.255 area 100
                     network 20.0.4.0 0.0.0.255 area 100
                     network 20.0.5.0 0.0.0.255 area 100
                     network 192.168.1.0 0.0.0.255 area 100
                     network 192.168.2.0 0.0.0.255 area 100
                    router rip
                     redistribute ospf 100
                     passive-interface Serial0/1
                     network 20.0.0.0
                     default-metric 100
                    ip http server
                    ip flow-export source Serial0/0
                    ip flow-export version 5
                    ip flow-export destination 21.0.0.78 9996
                    logging source-interface Serial0/0
                    logging 21.0.0.78
                    snmp-server community marstring RW
                    snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
                    snmp-server host 21.0.0.78 marstring
                    control-plane
                    line aux 0
                    Router#
                         Router#show ip rout
                    R    21.0.0.0/8 [120/1] via 20.0.0.2, 00:00:05, Serial0/0
                         20.0.0.0/24 is subnetted, 5 subnets
                    C       20.0.4.0 is directly connected, Loopback3
                    C       20.0.5.0 is directly connected, Loopback4
                    C       20.0.0.0 is directly connected, Serial0/0
                    C       20.0.1.0 is directly connected, Loopback0
                    C       20.0.3.0 is directly connected, Loopback1
                         22.0.0.0/24 is subnetted, 1 subnets
                    C       22.0.0.0 is directly connected, FastEthernet1/0
                    O E2 40.0.0.0/8 [110/100] via 192.168.2.2, 00:20:28, Serial0/1.2
                         10.0.0.0/32 is subnetted, 5 subnets
                    O       10.0.5.104 [110/65] via 192.168.1.2, 00:20:28, Serial0/1.1
                    O       10.0.4.103 [110/65] via 192.168.1.2, 00:20:28, Serial0/1.1
                    O       10.0.2.101 [110/65] via 192.168.1.2, 00:20:29, Serial0/1.1
                    O       10.0.3.102 [110/65] via 192.168.1.2, 00:20:29, Serial0/1.1
                    O       10.0.1.100 [110/65] via 192.168.1.2, 00:20:29, Serial0/1.1
                    C    192.168.1.0/24 is directly connected, Serial0/1.1
                    C    192.168.2.0/24 is directly connected, Serial0/1.2
                         30.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
                    O E2    30.0.0.0/24 [110/20] via 192.168.2.2, 00:20:29, Serial0/1.2
                    O       30.0.6.104/32 [110/65] via 192.168.2.2, 00:20:29, Serial0/1.2
                    O       30.0.3.101/32 [110/65] via 192.168.2.2, 00:20:29, Serial0/1.2
                    O       30.0.1.100/32 [110/65] via 192.168.2.2, 00:20:29, Serial0/1.2
                    O       30.0.5.103/32 [110/65] via 192.168.2.2, 00:20:29, Serial0/1.2
                    O       30.0.4.102/32 [110/65] via 192.168.2.2, 00:20:29, Serial0/1.2
                    Router#
                    còn trên HN thì chỉ bảng route chỉ thấy
                      Router#sho ip rout
                         21.0.0.0/24 is subnetted, 1 subnets
                    C       21.0.0.0 is directly connected, FastEthernet1/0
                    R       20.0.4.0 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R       20.0.5.0 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R       20.0.1.0 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R       20.0.3.0 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R    22.0.0.0/8 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R    192.168.1.0/24 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    R    192.168.2.0/24 [120/1] via 20.0.0.1, 00:00:16, Serial0/0
                    Router#
                    router HCM
                         Router#sho run
                    Current configuration : 1796 bytes
                    version 12.4
                    hostname Router
                    boot-start-marker
                    boot-end-marker
                    no aaa new-model
                    resource policy
                    memory-size iomem 5
                    ip cef
                    interface Loopback0
                     ip address 30.0.1.100 255.255.255.0
                    interface Loopback1
                     ip address 30.0.3.101 255.255.255.0
                    interface Loopback2
                     ip address 30.0.4.102 255.255.255.0
                    interface Loopback3
                     ip address 30.0.5.103 255.255.255.0
                    interface Loopback4
                     ip address 30.0.6.104 255.255.255.0
                    interface Serial0/0
                    interface Serial0/0.1 point-to-point
                    interface Serial0/1
                     ip address 30.0.0.1 255.255.255.0
                    interface Serial0/2
                     shutdown
                    interface Serial0/3
                     shutdown
                    router eigrp 200
                     redistribute ospf 100 metric 100000 1 255 1 1500
                     network 30.0.0.0 0.0.0.255
                     no auto-summary
                    router ospf 100
                     no auto-cost
                     redistribute eigrp 200 subnets
                     network 30.0.1.0 0.0.0.255 area 100
                     network 30.0.3.0 0.0.0.255 area 100
                     network 30.0.4.0 0.0.0.255 area 100
                     network 30.0.5.0 0.0.0.255 area 100
                     network 30.0.6.0 0.0.0.255 area 100
                     default-metric 100
                    ip http server
                    control-plane
                    line aux 0
                    Router#
                    tù hn ko ping được tới vùng eigrp của hcm
                    và từ ct củng ko ping tới hn được chỉ ping tới hp được àh
                      vậy làm sao để cho hn thấy các route khác(ct,hcm,bl) nhỉ?
                      bác cho e biết e bị sai chỗ nào nhỉ?
                      làm hoài ko ra
                        RIP version 1 có tối đa 16 hop counts. Bạn Redistribute từ OSPF vào RIP mà dùng default metric lên đến 100 thì các route do OSPF đưa qua sẽ xem như "unreachable". Chỉnh lại default metric bằng 3 (<16) là được.
                          thank bác! e làm oki rồi!
                          • Working...
