sh run
Current configuration:
version 12.0
service timestamps log uptime
hostname singapore
ip subnet-zero
interface Loopback0
no ip directed-broadcast
interface Ethernet0
shutdown
interface Serial0
ip address 192.168.240.1 255.255.255.252
no ip mroute-cache
no fair-queue
clockrate 64000
interface Serial1
ip address 192.168.224.1 255.255.255.252
clockrate 64000
interface BRI0
shutdown
router rip
version 2
network 192.168.3.0
network 192.168.224.0
network 192.168.240.0
ip classless
transport input none
line aux 0
singapore#
singapore#
singapore#
singapore#sh ipro route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
192.168.224.0/30 is subnetted, 1 subnets
C 192.168.224.0 is directly connected, Serial1
192.168.240.0/30 is subnetted, 1 subnets
C 192.168.240.0 is directly connected, Serial0
R 192.168.252.0/24 [120/1] via 192.168.240.2, 00:00:17, Serial0
C 192.168.3.0/24 is directly connected, Loopback0
singapore#
singapore#
singapore#
singapore#
singapore#
singapore#
singapore#
sanjose3#
sanjose3#
sanjose3#sh run
version 12.1
hostname sanjose3
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 192.168.1.3 255.255.255.0
interface Ethernet0
ip address 200.200.50.2 255.255.255.0
interface Serial0
ip address 192.168.224.2 255.255.255.252
interface Serial1
shutdown
router rip
version 1
network 192.168.1.0
ip classless
ip http server
logging synchronous
line aux 0
login
sanjose3#
sanjose3#
sanjose3#
sanjose3#sh ip route
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
C 192.168.224.0 is directly connected, Serial0
C 200.200.50.0/24 is directly connected, Ethernet0
C 192.168.1.0/24 is directly connected, Loopback0
sanjose3#
sanjose3#
sanjose3#
auckland#
auckland#
auckland#
auckland#sh run
version 12.0
hostname auckland
ip subnet-zero
interface Loopback0
ip address 192.168.252.1 255.255.255.0
interface Ethernet0
shutdown
interface Serial0
ip address 192.168.240.2 255.255.255.252
no ip mroute-cache
no fair-queue
interface Serial1
shutdown
interface BRI0
shutdown
router rip
version 2
network 192.168.252.0
ip classless
line aux 0
auckland#
auckland#
auckland#
auckland#sh ip route
R 192.168.224.0/24 [120/1] via 192.168.240.1, 00:00:17, Serial0
C 192.168.252.0/24 is directly connected, Loopback0
R 192.168.3.0/24 [120/1] via 192.168.240.1, 00:00:17, Serial0
auckland#
auckland#
auckland#
auckland#
sh ip route
R 192.168.224.0/24 [120/1] via 192.168.240.1, 00:00:21, Serial0
R 192.168.1.0/24 [120/2] via 192.168.240.1, 00:00:22, Serial0
R 192.168.3.0/24 [120/1] via 192.168.240.1, 00:00:22, Serial0
auckland#
auckland#
auckland#
sanjose3#
sanjose3#
sanjose3#
R 192.168.1.0/24 [120/1] via 192.168.224.2, 00:00:09, Serial1
R 192.168.252.0/24 [120/1] via 192.168.240.2, 00:00:00, Serial0
singapore#
singapore#
singapore#
singapore#
sanjose3#debug ip rip
RIP protocol debugging is on
sanjose3#clear ip route *
sanjose3#
00:35:18: RIP: sending request on Loopback0 to 255.255.255.255
00:35:18: RIP: sending request on Serial0 to 255.255.255.255
sanjose3#
00:35:20: RIP: sending v1 flash update to 255.255.255.255 via Loopback0 (192.168.1.3)
00:35:20: RIP: build flash update entries
00:35:20: network 192.168.224.0 metric 1
00:35:20: RIP: sending v1 flash update to 255.255.255.255 via Serial0 (192.168.224.2)
00:35:20: network 192.168.1.0 metric 1
sanjose3#
00:35:28: RIP: sending v1 update to 255.255.255.255 via Loopback0 (192.168.1.3)
00:35:28: RIP: build update entries
00:35:28: network 192.168.224.0 metric 1
00:35:28: RIP: sending v1 update to 255.255.255.255 via Serial0 (192.168.224.2)
00:35:28: network 192.168.1.0 metric 1
00:35:29: RIP: ignored v2 packet from 192.168.224.1 (illegal version)
sanjose3#
sanjose3#
sanjose3#
sanjose3#un all
All possible debugging has been turned off
sanjose3#
sanjose3#
RIP illegal version
sanjose3#
sanjose3#
sanjose3#conf t
sanjose3(config)#int s0
sanjose3(config-if)#ip rip re
sanjose3(config-if)#ip rip receive ver
sanjose3(config-if)#ip rip receive version 2
sanjose3(config-if)#^Z
sanjose3#
sanjose3#
R 192.168.240.0/24 [120/1] via 192.168.224.1, 00:00:00, Serial0
R 192.168.252.0/24 [120/2] via 192.168.224.1, 00:00:00, Serial0
R 192.168.3.0/24 [120/1] via 192.168.224.1, 00:00:00, Serial0
R 192.168.240.0/24 [120/1] via 192.168.224.1, 00:00:04, Serial0
R 192.168.252.0/24 [120/2] via 192.168.224.1, 00:00:04, Serial0
R 192.168.3.0/24 [120/1] via 192.168.224.1, 00:00:04, Serial0
sanjose3#
RIP1 & RIP2 can't understand eachother.
RIP: sending v2 update to 224.0.0.9 via Loopback0 (192.168.3.1)
RIP: ignored v2 packet from 192.168.3.1 (sourced from one of our addresses)
