Chào các bạn !
Nếu bạn nào quan tâm đến BGP-challenge lab (BSCI) thì hãy discuss cùng mình về config này.
RouterISPA :
int s0
description connect to sanjose1
ip add 10.0.0.5 255.255.255.252
int s1
description connect to sanjose3
ip add 10.0.0.1 255.255.255.252
int lo0
ip add 11.0.0.1 255.0.0.0
access-list 1 permit 11.0.0.0 0.255.255.255
access-list 2 permit 192.168.0.0 0.0.255.255
route-map NONET11
match ip address 1
set community no-export
exit
route-map DIRECT
match ip address 2
set local-preference 150
exit
route-map VIADIRECT
match ip address 1
set metric 50
exit
router bgp 100
network 11.0.0.0 mask 255.0.0.0
neighbor 10.0.0.6 remote-as 300
neighbor 10.0.0.6 route-map NONET11 out
neighbor 10.0.0.6 send-community
neighbor 10.0.0.6 route-map DIRECT in
neighbor 10.0.0.2 remote-as 300
neighbor 10.0.0.2 route-map NONET11 out
neighbor 10.0.0.2 send-community
Router ISP1B :
hostname ISP1B
int s0
description connect to sanjose2
ip add 172.6.0.5 255.255.255.252
int s1
ip add 172.6.0.1 255.255.255.252
int lo0
ip add 12.0.0.1 255.0.0.0
access-list 1 permit 12.0.0.0 0.255.255.255
route-map NONET12
match ip address 1
exit
route-map DIRECT
match ip address 2
exit
route-map VIADIRECT
match ip address 1
set metric 50
exit
router bgp 200
network 12.0.0.0 mask 255.0.0.0
neighbor 172.6.0.2 remote-as 300
neighbor 172.6.0.2 route-map NONET12 out
neighbor 172.6.0.2 send-community
neighbor 172.6.0.6 remote-as 300
neighbor 172.6.0.6 route-map NONET12 out
neighbor 172.6.0.6 send-community
neighbor 172.6.0.6 route-map DIRECT in
Router SanJose3
hotname SanJose3
int s0
description connect to ISP1A
ip add 10.0.0.2 255.255.255.252
int s1
description connect to ISP1B
ip add 172.6.0.2 255.255.255.252
int e0
description connect to LAn1_192.168.0.0
ip add 192.168.0.2 255.255.255.0
int e1
description connect to LAn1_192.168.1.0
ip add 192.168.1.3 255.255.255.0
int lo0
ip add 192.168.192.1 255.255.255.252
int lo1
ip add 192.168.208.1 255.255.255.252
int lo2
ip add 192.168.224.1 255.255.255.252
access-list 1 permit 192.168.0.0.0 255.255.0.0
router bgp 300
redistribute ospf 1
neighbor 172.6.0.1 remote-as 200
neighbor 172.6.0.1 distribute-list 1 out
neighbor 10.0.0.1 distribute-list 1 out
neighbor 10.0.0.1 remote-as 100
neighbor 192.168.1.2 remote-as 300
neighbor 192.168.1.2 next-hop-self
neighbor 192.168.1.2 route-reflector-client
neighbor 192.168.0.1 remote-as 300
neighbor 192.168.0.1 next-hop-self
neighbor 192.168.0.1 route-reflector-client
aggregate-address 192.168.0.0 255.255.0.0 summary-only
router ospf 1
network 192.168.0.0 0.0.255.255 area 0
redistribute connected subnets
Router SanJose1
int s0
ip add 10.0.0.6 255.255.255.252
int e0
ip add 192.168.0.1 255.255.255.0
int e1
ip add 192.168.1.1 255.255.255.0
int lo0
ip add 192.168.64.1 255.255.255.252
int lo1
ip add 192.168.80.1 255.255.255.252
int lo2
ip add 192.168.96.1 255.255.255.252
int lo3
ip add 192.168.112.1 255.255.255.252
access-list 1 permit 11.0.0.0 255.0.0.0
route-map TOISP1A
match ip address 1
router bgp 300
redistribute ospf 1
neighbor 10.0.0.5 remote-as 100
neighbor 10.0.0.5 route-map TOISP1A in
neighbor 192.168.0.2 remote-as 300
exit
router ospf 1
Router SanJose2
int s0
ip add 172.6.0.6 255.255.255.252
int e1
ip add 192.168.0.3 255.255.255.0
int e0
ip add 192.168.1.2 255.255.255.0
int lo0
ip add 192.168.64.5 255.255.255.252
int lo1
ip add 192.168.80.5 255.255.255.252
int lo2
ip add 192.168.96.5 255.255.255.252
int lo3
ip add 192.168.112.5 255.255.255.252
access-list 1 permit 12.0.0.0 255.0.0.0
route-map TOISP1B
match ip address 1
exit
router bgp 300
redistribute ospf 1
neighbor 172.6.0.5 remote-as 200
neighbor 172.6.0.5 route-map TOISP1B in
neighbor 192.168.1.3 remote-as 300
exit
router ospf 1
exit
Mong rằng các bạn hãy đọc kỹ config này và tham khảo thêm những sách Lab BSCI để cùng thảo luận về bài lab này nhé !
Xin cám ơn !
