Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
Thread: Làm sao để đổi password Router?
  1. #41
    Talking
    write va write mem co tac dung nhu nhau. ko tin kiem con router nao ma thu.
    nghe chung cai viec doi pass telnet cua ong notme vat va qua. cac huong dan deu dung ca day, neu ko lam dc thi hinh nhu dang tim cach chui vao con router nao do de pha day
  2. #42
    Default
    Trong trường hợp nào đó lỡ ta quên mất password thì phải làm thế nào?:rolleyes:
  3. #43
    Default
    nếu lỡ quên password:
    1 - nếu chưa write mem --> restart lại router
    2 - nếu đã write mem --> thực hiện các bước password recovery
  4. #44
    Default
    Tui de nghi cách như sau, ban thử làm xem nha. http://www.cisco.com/en/US/products/...80094675.shtml
    Ban vao trang đó đi, đây là cách bạn config từ cổng consol
    chuc thanh cong!
  5. #45
    Default
    Sợ ông kô bít cách xem, nên tui copy lun ra đây
    Step-by-Step Procedure
    To recover your password, complete these steps:
    Attach a terminal or PC with terminal emulation to the console port of the router.
    Use these terminal settings:
    9600 baud rate
    No parity
    8 data bits
    1 stop bit
    No flow control
    For more information on cabling, and details about how to connect a terminal to the console port or the AUX port, visit these links:
    Cabling Guide for Console and AUX Ports on Cisco Routers
    Connect a Terminal to Catalyst 2948G-L3, 4908G-L3, and 4840G Series Switches
    Catalyst 8510CSR, and 8540CSR Switches Console Port Pinouts
    If you still have access to the router, type show version , and record the setting of the configuration register. It is usually 0x2102 or 0x102.
    For a sample output of the show version command, refer to the Example of Password Recovery Procedure section.
    If you do not have access to the router (because of a lost login or TACACS password), you can safely consider that your configuration register is set to 0x2102.
    Use the power switch to turn off the router, and then turn it back on.
    Important: To simulate step 4 on a Cisco 6400, pull out and then replace the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
    Important: To simulate step 4 on a Cisco 6x00 using NI-2, pull out and then replace the NI-2 card.
    Press Break on the terminal keyboard within 60 seconds of the power-up to put the router into ROMMON.
    If the break sequence does not work, see Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    Type confreg 0x2142 at the rommon 1> prompt to boot from Flash without loading the configuration.
    Type reset at the rommon 2> prompt.
    The router reboots but ignores its saved configuration.
    Type no after each setup question or press Ctrl-C to skip the initial setup procedure.
    Type enable at the Router> prompt.
    You are taken to the enable mode, and the Router# prompt appears.
    Important: Type configure memory or copy startup-config running-config to copy the nonvolatile RAM (NVRAM) into memory.
    Do not type configure terminal .
    Type write terminal or show running-config .
    The show running-config and write terminal commands show the configuration of the router. In this configuration you see under all the interfaces the shutdown command, which means all interfaces are currently shutdown. Also, you can see the passwords (enable password, enable secret, vty, console passwords, and so on) either in encrypted or unencrypted format. The unencrypted passwords can be re-used, the encrypted ones will have to be changed with a new one.
    Type configure terminal and make the changes.
    The prompt is now hostname(config)#.
    Type enable secret <password> to change the enable secret password, for example.
    Issue the no shutdown command on every interface that is used.
    If you issue a show ip interface brief command, every interface that you want to use should be "up up".
    Type config-register 0x2102, or the value you recorded in step 2.
    Press Ctrl-Z or end to leave the configuration mode.
    The prompt is now changed to hostname#.
    Type write memory or copy running-config startup-config to commit the changes.
    The example in this section presents an actual password recovery procedure. We used a Cisco 2600 to create this example. Even if you do not use a Cisco 2600, this example will be almost exactly what you experience on your product.
    Router>enable
    Password:
    Password:
    Password:
    % Bad secrets
    Router>show version
    IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
    Copyright (c) 1986-1999 by cisco Systems, Inc.
    Compiled Tue 07-Dec-99 02:21 by phanguye
    Image text-base: 0x80008088, data-base: 0x80C524F8
    ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
    Router uptime is 3 minutes
    System returned to ROM by abort at PC 0x802D0B60
    System image file is "flash:c2600-is-mz.120-7.T"
    cisco 2611 (MPC860) processor (revision 0x202) with 26624K/6144K bytes of memory.
    Processor board ID JAB031202NK (3878188963)
    M860 processor: part number 0, mask 49
    Bridging software.
    X.25 software, Version 3.0.0.
    Basic Rate ISDN software, Version 1.1.
    2 Ethernet/IEEE 802.3 interface(s)
    2 Serial(sync/async) network interface(s)
    1 ISDN Basic Rate interface(s)
    32K bytes of non-volatile configuration memory.
    8192K bytes of processor board System flash partition 1 (Read/Write)
    8192K bytes of processor board System flash partition 2 (Read/Write)
    Configuration register is 0x2102
    Router>
    !--- The router was just powercycled and during bootup a
    !--- break sequence was sent to the router.
    *** System received an abort due to Break Key ***
    signal= 0x3, code= 0x500, context= 0x813ac158
    PC = 0x802d0b60, Vector = 0x500, SP = 0x80006030
    rommon 1 > confreg 0x2142
    You must reset or power cycle for new config to take effect
    rommon 2 > reset
    Copyright (c) 1999 by cisco Systems, Inc.
    TAC:Home:SW:IOS:Specials for info
    C2600 platform with 32768 Kbytes of main memory
    program load complete, entry point: 0x80008000, size: 0x6fdb4c
    Self decompressing the image : ###############################
    ############################### [OK]
    Restricted Rights Legend
    Use, duplication, or disclosure by the Government is
    subject to restrictions as set forth in subparagraph
    (c) of the Commercial Computer Software - Restricted
    Rights clause at FAR sec. 52.227-19 and subparagraph
    (c) (1) (ii) of the Rights in Technical Data and Computer
    Software clause at DFARS sec. 252.227-7013.
    cisco Systems, Inc.
    170 West Tasman Drive
    San Jose, California 95134-1706
    Bridging software.
    --- System Configuration Dialog ---
    Would you like to enter the initial configuration dialog? [yes/no]: n
    Press RETURN to get started!
    00:00:19: %LINK-3-UPDOWN: Interface BRI0/0, changed state to up
    00:00:19: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
    00:00:19: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
    00:00:19: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
    00:00:19: %LINK-3-UPDOWN: Interface Serial0/1, changed state to down
    00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0,
    00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0,
    changed state to up
    Router>
    00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1,
    changed state to up
    00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0,
    00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1,
    00:00 %SYS-5-RESTART: System restarted --
    00:00 %LINK-5-CHANGED: Interface BRI0/0,
    changed state to administratively down
    00:00 %LINK-5-CHANGED: Interface Ethernet0/0,
    00:00 %LINK-5-CHANGED: Interface Serial0/0,
    00:00 %LINK-5-CHANGED: Interface Ethernet0/1,
    00:00 %LINK-5-CHANGED: Interface Serial0/1,
    00:00 %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0,
    00:00 %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1,
    Router>
    Router>enable
    Router#copy startup-config running-config
    Destination filename [running-config]?
    1324 bytes copied in 2.35 secs (662 bytes/sec)
    Router#
    00:01:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0:1,
    00:01:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0:2,
    Router#configure terminal
    Router(config)#enable secret < password > [Choose a strong password with at least one capital letter, one number, and one special character.]
    Router(config)#^Z
    00:01 %SYS-5-CONFIG_I: Configured from console by console
    Router#show ip interface brief
    Ethernet0/0 10.200.40.37 YES TFTP administratively down down
    Serial0/0 unassigned YES TFTP administratively down down
    BRI0/0 193.251.121.157 YES unset administratively down down
    BRI0/0:1 unassigned YES unset administratively down down
    BRI0/0:2 unassigned YES unset administratively down down
    Ethernet0/1 unassigned YES TFTP administratively down down
    Serial0/1 unassigned YES TFTP administratively down down
    Loopback0 193.251.121.157 YES TFTP up up
    Router(config)#interface Ethernet0/0
    Router(config-if)#no shutdown
    Router(config-if)#
    00:02:14: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
    00:02:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0,
    changed state to up
    Router(config-if)#interface BRI0/0
    Router(config-if)#
    00:02:26: %LINK-3-UPDOWN: Interface BRI0/0:1, changed state to down
    00:02:26: %LINK-3-UPDOWN: Interface BRI0/0:2, changed state to down
    00:02:26: %LINK-3-UPDOWN: Interface BRI0/0, changed state to up
    00:02:115964116991: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0,
    TEI 68 changed to up
    Router(config-if)#^Z
    Router#
    00:02:35: %SYS-5-CONFIG_I: Configured from console by console
    Router#copy running-config startup-config
    Destination filename [startup-config]?
    [OK]
    Router#show version
    Bridging software.
    Configuration register is 0x2142
    Router(config)#config-register 0x2102
    Router(config)#^Z
    00:03:20: %SYS-5-CONFIG_I: Configured from console by console
    Router#show version
    Bridging software.
    Configuration register is 0x2142 (will be 0x2102 at next reload)
    Router#
  6. #46
    Default
    Lạy hồn
    Em đọc cái này mà cười đến chảy cả nước mắt. Có mỗi cái đổi pass mà các bác cứ lằng nhằng mãi, chẳng bác nào hướng dẫn chuẩn tắc cả. CHÁN DÂN CISCO VN QUÁ
    Em cũng o hiểu ông cụ nhà mình định làm gì nữa, nếu được quyền quản trị Router mà o biết cách sử lí về pass thì 100% ông bác này đang quậy phá.
    Thế nên anh em ngồi nghỉ đi nhé.
    Còn về vấn đề quên mật khẩu, để recovery pass, thì bác phải ngồi được bên cạnh con router, tức là phải thực sự là chủ của nó.
    Bác có thể coi trực tiếp về các recovery pass trên trang của cisco.
    tìm phần thiết bị đó, nó sẽ có tài liệu cụ thể
    Với Switch và router có chỗ ngược nhau,
    Switch thì giữ nút MODE sau đó mới căm nguồn điện
    Router thì tôi nhớ o rõ là dùng nút nào, tùy thiết bị, nhưng mà phải cắm điện rồi mới Ctrl Break thì phải
    Huy Bắc
    CÒn nếu bác nào chưa tìm được thì đưa lại serial của Router đó, tôi sẽ tìm tài liệu cho
    The Mumble Fund
    Vui long vao:
    De cung ket noi.
    Yahoo: huybac_nguyen
    Mail: huybac.nguyen@gmail.com
    Techcombank: 13320037822012
    Vietcombank: 0611001454910
  7. #47
    Default
    cuối cùng chỉ còn lại những người ở lại tám với nhau thôi.
    reply nhiêu đó mà còn ko hiểu nữa thì... đúng chán bác wlansecu nhỉ
  8. #48
    Default
    sao tôi đổi pass 2620, đánh lệnh login nó lại báo lỗi như dòng bên dưới?
    UBQN_R01(config)#line vty 0 4
    UBQN_R01(config-line)#login
    % Incomplete command.
  9. Default
    Để lệnh login có hiệu lực, bạn phải gõ lệnh
    password cisco trước
    sau đó, mới gõ lệnh
    login
  10. #50
    Default
    Nếu telnet vào Router mà mất pass thì không có cách nào xử lý được. Còn nếu có pass cũ mà chỉ sử lại thành pass mới thì quá đơn giản! Trong trường hợp mất pass chỉ còn cách cosole thì mới phá được pass.
    Học chăm không bằng đi học!
Similar Threads
  1. Replies: 9
    Last Post: 20-06-2012, 02:04 PM
  2. Lab 1-2: Đặt mật khẩu cho router
    By admin in forum CCNA LabPro
    Last Post: 26-07-2010, 11:38 AM
  3. Replies: 2
    Last Post: 24-08-2008, 03:09 PM
  4. Mời các mod viết tiếp qui trình cấu hình router - CCNA
    By dangquangminh in forum ICND 1 - Basic Router/Switch Config
    Last Post: 27-02-2004, 11:31 AM
  5. lệnh dialer map
    By tuaninbox in forum ISCW
    Last Post: 03-06-2003, 12:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
   TRUNG TÂM TIN HỌC VNPRO
Phone:(08) 35124257
Email: vnpro@vnpro.org
