Results 1 to 8 of 8
Thread: LAB-MPLS VPN Multi_VRF
  1. #1
    Default LAB-MPLS VPN Multi_VRF
    Trong mô hình MPLS VPN,khách hàng ở nhiều chi nhánh khác nhau kết nối vào mạng core MPLS có thể dùng dynamic routing protocal giữa các chi nhánh
    Attached Images Attached Images
    Attached Files Attached Files
  2. #2
    Default
    Qui hoạch IP:
    (1) 192.168.1.0/24
    (2) 192.168.2.0/24
    (3) 192.168.3.0/24
    (4) 192.168.4.0/24
    (5) 192.168.5.0/24
    (6) 192.168.6.0/24
    (7) Lo0: 10.10.10.10/24
    (8) Lo0: 20.20.20.20/24
    (9) Lo0: 1.1.1.1/24
    (10) Lo0: 3.3.3.3/24
    (11) Lo0: 2.2.2.2/24
    (12) Lo0: 30.30.30.30/24
    (13) Lo0: 40.40.40.40/24
  3. #3
    Default
    ROUTER A1:
    hostname A1
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    ip audit po max-events 100
    interface Loopback0
    ip address 10.10.10.10 255.255.255.0
    interface FastEthernet0/0
    duplex auto
    speed auto
    interface FastEthernet0/1
    shutdown
    duplex auto
    speed auto
    router eigrp 10
    network 10.0.0.0
    network 192.168.1.0
    no auto-summary
    ip classless
    ip http server
    no ip http secure-server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
    ROUTER B1:
    hostname B1
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 20.20.20.20 255.255.255.0
    shutdown
    duplex auto
    speed auto
    interface Serial0/0
    clock rate 2000000
    ip address 100.100.100.100 255.255.255.0
    duplex auto
    speed auto
    no keepalive
    interface Serial0/1
    shutdown
    clock rate 2000000
    router eigrp 20
    network 20.0.0.0
    network 100.0.0.0
    network 192.168.2.0
    no auto-summary
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
  4. #4
    Default
    ROUTER PE01:
    hostname PE01
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    ip vrf A1
    rd 1:100
    route-target export 1:100
    route-target import 1:100
    ip vrf B1
    rd 1:200
    route-target export 1:200
    route-target import 1:200
    interface Loopback0
    ip address 1.1.1.1 255.255.255.0
    ip vrf forwarding A1
    duplex auto
    speed auto
    interface Serial0/0
    ip vrf forwarding B1
    clock rate 64000
    duplex auto
    speed auto
    mpls label protocol ldp
    tag-switching ip
    interface Serial0/1
    shutdown
    clock rate 2000000
    router eigrp 100
    auto-summary
    address-family ipv4 vrf B1
    network 192.168.2.0
    no auto-summary
    autonomous-system 20
    exit-address-family
    address-family ipv4 vrf A1
    network 192.168.1.0
    no auto-summary
    autonomous-system 10
    exit-address-family
    router rip
    version 2
    network 1.0.0.0
    network 192.168.3.0
    no auto-summary
    router bgp 1
    no synchronization
    bgp log-neighbor-changes
    neighbor 2.2.2.2 remote-as 1
    neighbor 2.2.2.2 update-source Loopback0
    no auto-summary
    address-family vpnv4
    neighbor 2.2.2.2 activate
    neighbor 2.2.2.2 send-community extended
    exit-address-family
    redistribute eigrp 20
    no auto-summary
    no synchronization
    exit-address-family
    redistribute eigrp 10
    no auto-summary
    no synchronization
    exit-address-family
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
    ROUTER P:
    hostname P
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 3.3.3.3 255.255.255.0
    ip address 192.168.3.2 255.255.255.0
    duplex auto
    speed auto
    tag-switching ip
    ip address 192.168.4.1 255.255.255.0
    duplex auto
    speed auto
    tag-switching ip
    router rip
    version 2
    network 3.0.0.0
    network 192.168.3.0
    network 192.168.4.0
    no auto-summary
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
    ROUTER PE02:
    hostname PE02
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    ip vrf A2
    rd 1:100
    ip vrf B2
    rd 1:200
    interface Loopback0
    ip address 2.2.2.2 255.255.255.0
    ip address 192.168.4.2 255.255.255.0
    duplex auto
    speed auto
    tag-switching ip
    interface Serial0/0
    ip vrf forwarding A2
    ip address 192.168.5.1 255.255.255.0
    clock rate 64000
    ip vrf forwarding B2
    ip address 192.168.6.1 255.255.255.0
    duplex auto
    speed auto
    interface Serial0/1
    shutdown
    clock rate 2000000
    router eigrp 100
    auto-summary
    address-family ipv4 vrf B2
    redistribute bgp 1 metric 1000 100 100 100 100
    network 192.168.6.0
    auto-summary
    autonomous-system 40
    exit-address-family
    address-family ipv4 vrf A2
    network 192.168.5.0
    auto-summary
    autonomous-system 30
    exit-address-family
    router rip
    version 2
    network 2.0.0.0
    network 192.168.4.0
    no auto-summary
    router bgp 1
    no synchronization
    neighbor 1.1.1.1 remote-as 1
    neighbor 1.1.1.1 update-source Loopback0
    no auto-summary
    neighbor 1.1.1.1 activate
    neighbor 1.1.1.1 send-community extended
    exit-address-family
    redistribute eigrp 40
    no auto-summary
    no synchronization
    exit-address-family
    redistribute eigrp 30
    no auto-summary
    no synchronization
    exit-address-family
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
  5. #5
    Default
    ROUTER A2:
    hostname A2
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 30.30.30.30 255.255.255.0
    shutdown
    duplex auto
    speed auto
    interface Serial0/0
    ip address 192.168.5.2 255.255.255.0
    clock rate 2000000
    shutdown
    duplex auto
    speed auto
    interface Serial0/1
    shutdown
    clock rate 2000000
    router eigrp 30
    network 30.0.0.0
    network 192.168.5.0
    no auto-summary
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
    ROUTER B2:
    hostname B2
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip subnet-zero
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 40.40.40.40 255.255.255.0
    ip address 192.168.6.2 255.255.255.0
    duplex auto
    speed auto
    shutdown
    duplex auto
    speed auto
    router eigrp 40
    network 40.0.0.0
    network 192.168.6.0
    no auto-summary
    ip classless
    ip http server
    exec-timeout 0 0
    line aux 0
    privilege level 15
    no login
    line vty 5 15
    privilege level 15
    no login
    End
  6. #6
    Default
    Kiểm tra hoạt động:
    • Đối với MPLS Domain :
    i. Kiểm tra bảng định tuyến :
    Trên PE01
    PE01#show ip route
    1.0.0.0/24 is subnetted, 1 subnets
    C 1.1.1.0 is directly connected, Loopback0
    2.0.0.0/24 is subnetted, 1 subnets
    R 2.2.2.0 [120/2] via 192.168.3.2, 00:00:12, FastEthernet0/1
    3.0.0.0/24 is subnetted, 1 subnets
    R 3.3.3.0 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
    R 192.168.4.0/24 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
    C 192.168.3.0/24 is directly connected, FastEthernet0/1
    Trên P
    P#show ip route
    R 1.1.1.0 [120/1] via 192.168.3.1, 00:00:07, FastEthernet0/0
    R 2.2.2.0 [120/1] via 192.168.4.2, 00:00:11, FastEthernet0/1
    C 3.3.3.0 is directly connected, Loopback0
    C 192.168.4.0/24 is directly connected, FastEthernet0/1
    C 192.168.3.0/24 is directly connected, FastEthernet0/0
    Trên PE02
    PE02#show ip route
    R 1.1.1.0 [120/2] via 192.168.4.1, 00:00:27, FastEthernet0/0
    C 2.2.2.0 is directly connected, Loopback0
    R 3.3.3.0 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
    C 192.168.4.0/24 is directly connected, FastEthernet0/0
    R 192.168.3.0/24 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
    Kết luận : Định tuyến nội giữa MPLS Domain đã thông, từ đó cấu hình MPLS
    ii. Kiểm tra LFIP table
    Trên PE01
    PE01#show mpls forwarding-table
    Local Outgoing Prefix Bytes tag Outgoing Next Hop
    tag tag or VC or Tunnel Id switched interface
    16 16 2.2.2.0/24 0 Fa0/1 192.168.3.2
    17 Pop tag 3.3.3.0/24 0 Fa0/1 192.168.3.2
    18 Pop tag 192.168.4.0/24 0 Fa0/1 192.168.3.2
    Trên P
    P#show mpls forwarding-table
    16 Pop tag 2.2.2.0/24 3375 Fa0/1 192.168.4.2
    17 Pop tag 1.1.1.0/24 5007 Fa0/0 192.168.3.1
    Trên PE02
    PE02#show mpls forwarding-table
    16 Pop tag 3.3.3.0/24 0 Fa0/0 192.168.4.1
    17 Pop tag 192.168.3.0/24 0 Fa0/0 192.168.4.1
    18 17 1.1.1.0/24 0 Fa0/0 192.168.4.1
    iii. Cấu hình BGP trên PE01 và PE02
    Trên PE01
    PE01#show ip bgp summary
    BGP router identifier 1.1.1.1, local AS number 1
    BGP table version is 1, main routing table version 1
    Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
    2.2.2.2 4 1 55 54 1 0 0 00:43:36 0
    Trên PE02
    PE02#show ip bgp summary
    BGP router identifier 2.2.2.2, local AS number 1
    1.1.1.1 4 1 55 56 1 0 0 0024 0
    - Kiểm tra vrf routing table của A1,A2,B1,B2 trên PE01 và PE02
    Trên PE01:
    PE01#show ip route vrf A1
    Routing Table: A1
    B 192.168.5.0/24 [200/0] via 2.2.2.2, 0007
    D 10.10.10.0 [90/156160] via 192.168.1.1, 0024, FastEthernet0/0
    C 192.168.1.0/24 is directly connected, FastEthernet0/0
    30.0.0.0/24 is subnetted, 1 subnets
    B 30.30.30.0 [200/2297856] via 2.2.2.2, 0007
    PE01#show ip route vrf B1
    Routing Table: B1
    100.0.0.0/24 is subnetted, 1 subnets
    D 100.100.100.0 [90/2172416] via 192.168.2.1, 0046, Serial0/0
    20.0.0.0/24 is subnetted, 1 subnets
    D 20.20.20.0 [90/2297856] via 192.168.2.1, 0046, Serial0/0
    40.0.0.0/24 is subnetted, 1 subnets
    B 40.40.40.0 [200/156160] via 2.2.2.2, 0020
    B 192.168.6.0/24 [200/0] via 2.2.2.2, 0020
    C 192.168.2.0/24 is directly connected, Serial0/0
    Trên PE02:
    PE02#show ip route vrf A2
    Routing Table: A2
    C 192.168.5.0/24 is directly connected, Serial0/0
    B 10.10.10.0 [200/156160] via 1.1.1.1, 0016
    B 192.168.1.0/24 [200/0] via 1.1.1.1, 0016
    D 30.30.30.0 [90/2297856] via 192.168.5.2, 0047, Serial0/0
    PE02#show ip route vrf B2
    Routing Table: B2
    B 100.100.100.0 [200/2172416] via 1.1.1.1, 0044
    B 20.20.20.0 [200/2297856] via 1.1.1.1, 0044
    D 40.40.40.0 [90/156160] via 192.168.6.2, 00:49:30, FastEthernet0/1
    C 192.168.6.0/24 is directly connected, FastEthernet0/1
    B 192.168.2.0/24 [200/0] via 1.1.1.1, 0059
    - Kiểm tra thông tuyến:
    A1#ping 30.30.30.30
    Sending 5, 100-byte ICMP Echos to 30.30.30.30, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 196/236/300 ms
    B1#ping 40.40.40.40
    Sending 5, 100-byte ICMP Echos to 40.40.40.40, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 156/180/200 ms
    - Kiểm tra bảng LFIP hoàn chỉnh trên mỗi Router PE01 và PE02:
    19 Untagged 20.20.20.0/24[V] 0 Se0/0 point2point
    20 Untagged 100.100.100.0/24[V] \
    0 Se0/0 point2point
    21 Untagged 10.10.10.0/24[V] 0 Fa0/0 192.168.1.1
    22 Aggregate 192.168.1.0/24[V] 520
    23 Aggregate 192.168.2.0/24[V] 520
    19 Untagged 30.30.30.0/24[V] 520 Se0/0 point2point
    20 Aggregate 192.168.5.0/24[V] 0
    21 Untagged 40.40.40.0/24[V] 570 Fa0/1 192.168.6.2
    22 Aggregate 192.168.6.0/24[V] 0
    - Kiểm tra cơ chế chuyển mạch nhãn tại MPLS Domain
    PE01#traceroute vrf A1 30.30.30.30
    Tracing the route to 30.30.30.30
    1 192.168.3.2 [MPLS: Labels 16/19 Exp 0] 160 msec 184 msec 144 msec
    2 192.168.5.1 [MPLS: Label 19 Exp 0] 128 msec 60 msec 92 msec
    3 192.168.5.2 176 msec * 216 msec
    PE02#traceroute vrf B2 20.20.20.20
    Tracing the route to 20.20.20.20
    1 192.168.4.1 [MPLS: Labels 17/19 Exp 0] 176 msec 120 msec 156 msec
    2 192.168.2.2 [MPLS: Label 19 Exp 0] 212 msec 64 msec 52 msec
    3 192.168.2.1 92 msec * 160 msec
  7. #7
    Default
    làm xong bài này em ping A1 sang PE01 được còn PE01 Ping sang A1 không được!!!!!Như vậy A2 chỉ ping được tới PE01, Ai biết tình huống này giúp mình với!!!!!
  8. #8
    Default
    ai chỉ với coi
Similar Threads
  1. Tìm hiểu MPLS những sách không thể thiếu,...
    By R3 in forum Các website và sách hữu ích cho việc học networking
    Last Post: 12-06-2012, 02:33 PM
  2. [Dùng GNS3}ISCW LAB: MPLS VPN ROUTING VRF
    By tranmyphuc in forum ISCW
    Last Post: 04-06-2012, 02:58 PM
  3. Một số câu hỏi về MPLS
    By vnpro_fan in forum Metro, MPLS, Optical Networking, Storage Networking
    Last Post: 27-02-2004, 11:27 AM
  4. support MPLS
    By booster in forum Metro, MPLS, Optical Networking, Storage Networking
    Last Post: 02-01-2004, 10:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
   TRUNG TÂM TIN HỌC VNPRO
Phone:(08) 35124257
Email: vnpro@vnpro.org
