MPLS Lab
  • MPLS Lab
    Chào mọi người,
    Mình có mô hình lab như hình vẽ. Mình chạy bằng Dynamips, cấu hình như sau:
    en
    conf t
    host P1-AS1
    int lo0
    ip add 10.10.10.200 255.255.255.255
    int s1/0
    ip add 10.10.10.2 255.255.255.252
    no shut
    mpls ip
    int s1/1
    ip add 10.10.10.6 255.255.255.252
    no shut
    mpls ip
    router ospf 1
    log-adjacency-changes
    network 10.0.0.0 0.255.255.255 area 0
    en
    conf t
    host PE1-AS1
    ip vrf CustA
    rd 1:100
    route-target export 1:100
    route-target import 1:100
    int lo0
    description RID for MP-BGP
    ip add 10.10.10.101 255.255.255.255
    int s1/0
    description connected to P1-As1
    ip add 10.10.10.1 255.255.255.252
    no shut
    mpls ip
    int s1/1
    description connected to CE1-A
    ip vrf forwarding CustA
    ip add 172.16.1.1 255.255.255.252
    no shut
    router eigrp 1
    no auto-summary
    address-family ipv4 vrf CustA
    redistribute bgp 1 metric 1000 100 255 1 1500
    network 172.16.0.0
    no auto-summary
    autonomous-system 101
    exit-address-family
    router ospf 1
    router-id 10.10.10.101
    router bgp 1
    no synchronization
    bgp log-neighbor-changes
    neighbor 10.10.10.102 remote-as 1
    neighbor 10.10.10.102 update-source Loopback0
    no auto-summary
    address-family vpnv4
    neighbor 10.10.10.102 activate
    neighbor 10.10.10.102 send-community both
    exit-address-family
    redistribute eigrp 101
    no auto-summary
    no synchronization
    exit-address-family
    en
    conf t
    host PE2-AS1
    ip vrf CustA
    rd 1:100
    int lo0
    ip add 10.10.10.102 255.255.255.255
    int s1/0
    description connected to P1-AS1
    ip add 10.10.10.5 255.255.255.252
    no shut
    mpls ip
    int s1/1
    description connected to PE2-A
    ip add 172.16.2.1 255.255.255.252
    no shut
    router eigrp 1
    auto-summary
    network 172.16.0.0
    no auto-summary
    exit-address-family
    router ospf 1
    router-id 10.10.10.102
    router bgp 1
    no synchronization
    neighbor 10.10.10.101 remote-as 1
    neighbor 10.10.10.101 update-source Loopback0
    no auto-summary
    neighbor 10.10.10.101 activate
    neighbor 10.10.10.101 send-community both
    exit-address-family
    no auto-summary
    no synchronization
    exit-address-family
    en
    conf t
    host CE1-A
    int fa0/0
    ip add 172.16.10.1 255.255.255.0
    no shut
    no keepalive
    int s1/0
    description connected to PE1-AS1
    ip add 172.16.1.2 255.255.255.252
    no shut
    router eigrp 101
    network 172.16.0.0
    no auto-summary
    en
    conf t
    host CE2-A
    int lo0
    ip add 172.16.99.1 255.255.255.0
    int fa0/0
    ip add 172.16.20.1 255.255.255.0
    no shut
    no keepalive
    int s1/0
    description connected to PE2-AS1
    ip add 172.16.2.2 255.255.255.252
    no shut
    router eigrp 101
    redistribute ospf 101
    passive-interface Loopback0
    network 172.16.0.0
    no auto-summary
    router ospf 101
    redistribute eigrp 101 subnets
    network 172.16.99.0 0.0.0.255 area 0
    Sau khi đã cấu hình xong, show ip route trên các CE cho kết quả:
    CE1-A#sho ip route
    172.16.0.0/16 is variably subnetted, 5 subnets, 2 masks
    D 172.16.20.0/24 [90/2684416] via 172.16.1.1, 00:10:11, Serial1/0
    C 172.16.10.0/24 is directly connected, FastEthernet0/0
    C 172.16.1.0/30 is directly connected, Serial1/0
    D 172.16.2.0/30 [90/2681856] via 172.16.1.1, 00:10:11, Serial1/0
    D 172.16.99.0/24 [90/2809856] via 172.16.1.1, 00:10:11, Serial1/0
    CE2-A#sho ip rou
    C 172.16.20.0/24 is directly connected, FastEthernet0/0
    D 172.16.10.0/24 [90/2684416] via 172.16.2.1, 00:10:14, Serial1/0
    D 172.16.1.0/30 [90/2681856] via 172.16.2.1, 00:10:14, Serial1/0
    C 172.16.2.0/30 is directly connected, Serial1/0
    C 172.16.99.0/24 is directly connected, Loopback0
    Tuy nhiên CE1-A không ping được CE2-A
    CE1-A#ping 172.16.2.2
    Sending 5, 100-byte ICMP Echos to 172.16.2.2, timeout is 2 seconds:
    Mình thử traceroute thì thấy packet bị kẹt trên PE1-As1
    CE1-A#traceroute 172.16.2.2
    Tracing the route to 172.16.2.2
    1 172.16.1.1 64 msec 100 msec 104 msec
    2 * * *
    3 * * *
    Cả hai PE1 & PE2 đều ping được tới các CE của nó:
    PE1-AS1#ping vrf CustA 172.16.10.1
    Sending 5, 100-byte ICMP Echos to 172.16.10.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 52/74/128 ms
    PE2-AS1#ping vrf CustA 172.16.20.1
    Sending 5, 100-byte ICMP Echos to 172.16.20.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 28/55/108 ms
    Tuy nhiên các lệnh show trên PE1-As1 và PE2-AS1 cho thấy cả 2 PE đều đã học đuợc route của nhau.
    PE1-AS1#ping 10.10.10.102[/B]
    Sending 5, 100-byte ICMP Echos to 10.10.10.102, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 56/88/128 ms
    PE1-AS1#sho ip rout vrf CustA
    Routing Table: CustA
    B 172.16.20.0/24 [200/2172416] via 10.10.10.102, 00:14:54
    D 172.16.10.0/24 [90/2172416] via 172.16.1.2, 00:15:45, Serial1/1
    C 172.16.1.0/30 is directly connected, Serial1/1
    B 172.16.2.0/30 [200/0] via 10.10.10.102, 00:14:54
    B 172.16.99.0/24 [200/2297856] via 10.10.10.102, 00:14:54
    PE2-AS1#sho ip rout vrf CustA
    D 172.16.20.0/24 [90/2172416] via 172.16.2.2, 00:15:52, Serial1/1
    B 172.16.10.0/24 [200/2172416] via 10.10.10.101, 00:14:59
    B 172.16.1.0/30 [200/0] via 10.10.10.101, 00:14:59
    C 172.16.2.0/30 is directly connected, Serial1/1
    D 172.16.99.0/24 [90/2297856] via 172.16.2.2, 00:15:52, Serial1/1
    PE1-AS1#sho ip bgp vpnv4 vrf CustA
    BGP table version is 11, local router ID is 192.168.101.1
    Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
    r RIB-failure, S Stale
    Route Distinguisher: 1:100 (default for vrf CustA)
    *> 172.16.1.0/30 0.0.0.0 0 32768 ?
    *>i172.16.2.0/30 10.10.10.102 0 100 0 ?
    *> 172.16.10.0/24 172.16.1.2 2172416 32768 ?
    *>i172.16.20.0/24 10.10.10.102 2172416 100 0 ?
    *>i172.16.99.0/24 10.10.10.102 2297856 100 0 ?
    PE2-AS1#sho ip bgp vpnv4 vrf CustA
    BGP table version is 11, local router ID is 192.168.102.1
    *>i172.16.1.0/30 10.10.10.101 0 100 0 ?
    *> 172.16.2.0/30 0.0.0.0 0 32768 ?
    *>i172.16.10.0/24 10.10.10.101 2172416 100 0 ?
    *> 172.16.20.0/24 172.16.2.2 2172416 32768 ?
    *> 172.16.99.0/24 172.16.2.2 2297856 32768 ?
    Nhờ các bạn troubleshoot giúp. Thanks
    CCIE#24929 (SP)
    Networking Forum: http://netspace.vn/forum
    Ban co cau hinh "ip cef" tren tat ca cac router chua?
    Trần Nhân Hòa
    CMND #0146257668
